white smoke issue
Old Jul 8, 2010 | 04:08 AM
robgee32's Avatar
robgee32
Default white smoke issue
hi all need help
got white smoke from exhaust on my zetec turbo i have done the head gasket put it is still there
could it be the turbo
also there is creamy stuff still getting into the head under the oil cap is this because the oil and oil filter needs changing due to water getting in to the oil or will it be somthing else
the engine is also idleing bad
can anyone please help
thanks
Old Jul 8, 2010 | 06:12 AM
oldford's Avatar
oldford
Sounds like head gasket problem, maybe even a cracked head.
Old Jul 8, 2010 | 06:38 AM
scottyrs's Avatar
scottyrs
DURHAM RSOC
i was going to say im no expert but headgasket
Old Jul 8, 2010 | 07:26 AM
martysmartie's Avatar
martysmartie
Sounds almost defo a head gasket or cracked head etc, easiest way to tell is to see if the coolant level has dropped if not chances are it's ok. It's not white smoke your seeing from exhaust rather it's steam where the coolant is getting boiled and then exhausted.
Another way is to check the plugs, if you see one plug is cleaner than the rest that indicates coolant has been in that cylinder which boils, efficiently steam cleaning that cylinder.
Martin
Old Jul 8, 2010 | 08:13 AM
You need to determine if it is oil or steam you are seeing, if water/steam it will dissapear almost immediately(on a hot day), if oil, this could be oil getting into exhaust on the exhaust side of the turbo, as it's not burnt(or would be blue), maybe have a look in exhaust next ?, looking for oil.
Old Jul 8, 2010 | 08:54 PM
robgee32's Avatar
robgee32
like i said in the post i have changed the head gasket and head has been checked and skimmed
but i was just wondering if there might be water left in the oil or turbo problem
will check if there is oil in the exhaust but wont this be blue not white
thanks
Old Jul 9, 2010 | 12:21 PM
martysmartie
No, blue smoke is when the oil is fried alive (Such as in the combustion chamber) if not it will be white smoke on exhaust side for example.
You should always change your Coolant and Oil after a HG change as the both of them will be cross contaminated so it could be the residue of this as you say.
Martin
bobsworth
77
Mar 24, 2016 09:30 PM
Mark_
14
Jan 16, 2016 05:27 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
