Fan Prob on Saff Cossie
Thank you all so much for the replies, im no doubt gonna do the fuel pump aswell,
Just out of curiosity when i re-done the fan circuit i ran an earth back to the battery, (Not earthed onto chassis) i connected the earth Fan Switch and the earth for the Fans in the Same wire. Is this ok.
Also does anyone know how i can make the connector (In my Pic C and D) redundant and have not power,
Thanks Guys
Thanks Guys
pull the fan fuse out (in the fuse box)
Thanks Guys
Thanks Guys
Had this happen to me on the weekend
, fans just stopped working turns out its a wire gone mushed across the front panel somewhere lol, so ive just done a full re wire with new relay doing away with the old setup in the fuse box.
A job worth doing that was with this heat anyway
i am gonna do mine as i tried a direct feed from the batterys to the fans and they work so must be old wiring causing the issues when thats sorted need to sort out the rear lights as they have a electrical fault and the abs light always being on
May be a simple fix. If it's on all the time, remove the 2 pin connector from the brake fluid reservoir and temporarily join the 2 wires (a short bit of wire shoved into the terminals will do nicely). If the light goes out, then either the brake fluid level is a little low, or you need a new reservoir cap.
Only thing you could have disturbed by doing this would be the ABS sensors there is one on each wheel hub. They can be removed from the hub and cleaned but they can be very tight in the hub itself so patience is a virtue as they say.
Martin
Martin
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
