best way to weld gear box case?
hiya
have got a 10mm hole in the bottom of my gear box and would like to know the best way to weld this?
i have a mig and can weld with that no problem but never welded alloy before. any advise would be great
cheers mark
cheers mark
As above MIG will deffo not be up to the job.
You need a good tig and also need to be very very good with it otherwise you'll end up blowing holes in the case.
My brother in law is an ex stainless and alloy fabricater who is working with my old man in the gearbox trade and it him about 3 months to master the art of welding the cases. Even now he only does it in very very special circumstances.
What box are you wanting to weld and why?
A mig will do it no problem, but will have to be a decent mig, as needs lots of heat input as alloy is such a good conductor of heat, can also as said be tigged or arcd, a local freindly tig place should soon sort it for you cheap enough.
thanks tabetha yeah have a good mig so will give it a go and see how it goes. lol worse that can happen is i put bigger hole in it i guess
steve long time no see mate. yeah still alive 'just' did wonder if i would see you at the pod on the rs day but as you might of probably guessed me car is knackered and tree had gone out for the day in the other one. how are you and family? my boy is one next month i cant believe how fast that has gone. but loving every bit of it, must catch up been to long!!!
personally i wouldnt be migging it as u'l find it harder to control the flow of product (wire) into the hole and may end up with a large build up on the inside or even worse bits inside . I'd get the tig out on a medium heat with a 3mm upwards 5% sillicone filler rod and take your time, if not get someone else to do it . Cheers Ally
TPM961
15-01-2018 10:50 AM
andrewmctiernan
08-09-2015 03:05 PM
