can you put new acid/water in an old battery?
iv left my car to stand for a week and now the battery has gone, it wont charge up over 11.5 volts, it will go over 11.5 when on charge but it will go back down after some time has past
iv seen in halfords you can buy replacment battery acid/water? will this work? or is it when a battery goes it goes?
any info would be great
thanks diesel
thanks diesel
Most likely dead, look at the plates, do they look bent twisted or broken ?
You can put in new acid to 1.280PH, but won't cure a dead battery.
A conditioner charger can often revive very sucessfully some dead batteries, the se conditioner chargers work in a different way to a steady state charger and are much better, last one I bought from LIDL for £15, only 3-4 amps but charge so quick due to the way they work, can can be left on 24/7 all year round, as it exercises the battery.
Sometimes they can be revived a bit by washing out, but hardly ever works.
If as it sounds the car is left long periods get a AGM, even fully flattened won't harm, won't cause sulphation like a std lead acid one, or other wise VARTA BLUE is the way to go.
when i took it off charge about 3 hours ago it was 12.84 and droped to 12.64 in the first hour but hasn,t droped anymore.
i allways thought a charger was a charger but going off what you have said seems to be right, it wouldn,t charge up properly with my other charger.
n1 thanks for you help
No probs matey, as you've seen a charger is not just a charger, the same type of charger as the £15 lidl conditioner charger sells for nearly £90 under a different name, even though made by same people!!
I've revived a battery that was flat for just over 1 year, didn't expect it to last, was just for getting engine started, 3 years on still going!!
cossie fan (unluckerly)
Best way to test a battery is with a drop tester put some amps through it that will soon tell u if its scrap! A volts meter can tell u its good all day long but a drop tester will let u know if its realy ok!
You CANNOT drop test a flat battery, if you do it fails miserably, and is thrown away, as above when all it may need is a conditioning cycle as above.
Hundreds of "dead" batteries are binned that can be revived after failing drop test, and offer many many years of service afterwards, after having been failed.
Passing a drop test as soon as charged will not show a internal short circuit, caused by debris/broken plate material, that will flatten it over a few days, drop test gives a clue but as I said seen so many recovered by conditioning, and done years and years service afterwards.
155lee
06-09-2016 11:10 AM
Adam Graham
06-09-2015 06:04 AM
