cosworth running problems
Old Apr 9, 2010 | 11:09 PM
  #41
Danny @ Enhanced Performance's Avatar
At the end of the daythe car will run on just about any set up but very ruth wot you have is to much air getting it .its the throttel body setup / air leak im 100% shower
dont know about the shower mate but other than that i tottaly agree,lol!!
cheers danny
Old Apr 9, 2010 | 11:10 PM
  #42
KW235's Avatar
KW235
My 09 is a red one.....sleeper Modus under the 3dr Bonnet.
Old Apr 9, 2010 | 11:12 PM
  #43
fostersice's Avatar
fostersice
ok so we all agree air leak ????
and that once i seal the leak i should first fun it standard
once i have the new 300bhp ecu i need to find out what inj it was run with and map sensor
once i know that i can use the ecu im buying along with the 3bar map sensor i have and i just need the in jectors to match the ecu??
Old Apr 9, 2010 | 11:14 PM
  #44
fostersice's Avatar
fostersice
i have the two best site all a man needs osf and passionford lol
just want to drive it for the first time lol
Old Apr 9, 2010 | 11:15 PM
  #45
KW235's Avatar
KW235
I think you need the 803 greens with the 300bhp ECU.
Old Apr 9, 2010 | 11:17 PM
  #46
COLEYST200's Avatar
COLEYST200
cheers danny
im shit at spelling
  #47
fostersice's Avatar
fostersice
thanks kw
i will see what i can find
Old Apr 9, 2010 | 11:19 PM
  #48
fostersice's Avatar
fostersice
im shit at spelling
glad your better with senigne (engines) lol
Old Apr 9, 2010 | 11:23 PM
  #49
COLEYST200's Avatar
COLEYST200
one last thing you have got a bit of free play in the throttel cable ?? as that could hold the butter fly open a bit . the butter fly need to be as close to being closed as poss you will see when you have a look in the morring
Old Apr 9, 2010 | 11:25 PM
  #50
fostersice's Avatar
fostersice
a really big thank you guys
im at work tomorrow so it will be sunday before i get to play
Old Apr 9, 2010 | 11:42 PM
  #51
botters's Avatar
botters
competant bodger
keep us posted with progress cus your car is awesome
Old Apr 10, 2010 | 07:56 PM
  #52
martysmartie's Avatar
martysmartie
The only way ECU can raise idle speed is via the ISCV, they can cause problems with sticking which could cause your problem, so unplug to eliminate. The standard chip with a 3 BAR MAP sensor will make it run rough as the output is totally different to the standard 2 BAR. If not ISCV then presuming you have the base idle set right will be an air leak. You also need sutiable injectors for the new chip and hopefully have a decent HG.
Martin
Old Apr 11, 2010 | 07:04 AM
  #53
fostersice's Avatar
fostersice
One last thing before I go out the strip down the plenum
Is the right the blue hose going from the -31 act to the turbo???
Old Apr 11, 2010 | 08:53 AM
  #54
rscos2004's Avatar
rscos2004
Default cosworth running problems.
Thats only if you are not running an amal valve.
Old Apr 11, 2010 | 11:11 AM
  #55
martysmartie
The hose goes from compressor housing to (C) on amal valve and from (W) to actuator (R) on amal valve vents to atmosphere.
Martin
Old Apr 11, 2010 | 01:26 PM
  #56
fostersice's Avatar
fostersice
Ok so i removed the plenum and the new gasket i fitted was all mest up inside so removed it and uses a gasket sealant
i now need to sort out it on idle as it seems to be hunting now lol
[IMG]
http://i142.photobucket.com/albums/r106/fostersice/classic%20rs2000/th_MOV05271.jpg[/IMG]
Old Apr 11, 2010 | 01:43 PM
  #57
fostersice's Avatar
fostersice
Old Apr 11, 2010 | 01:44 PM
  #58
COLEYST200's Avatar
COLEYST200
I win as i kept saying it was to much air getting in. wot is for dinner then
Old Apr 11, 2010 | 02:01 PM
  #59
fostersice's Avatar
fostersice
Old Apr 11, 2010 | 02:03 PM
  #60
fostersice's Avatar
fostersice
beef,mash, roast tats,sweed,carrets,plus the rest of the veg.
dinner is at 5mate see you soon
Old Apr 11, 2010 | 02:20 PM
  #61
COLEYST200's Avatar
COLEYST200
Nice
mate im happy its now running as you no to well now just ask if you have a problem and we will all see wot we can do
did you have a look at the link i sent you
Old Apr 11, 2010 | 02:54 PM
  #62
rscos2004's Avatar
rscos2004
Hi do you know the inlet is upside down it has been designed for the other way round i would do that first.
Old Apr 11, 2010 | 05:10 PM
  #63
COLEYST200's Avatar
COLEYST200
hi mate on some swedish plenums you have to flip them over and they still work ok like that
Old Apr 11, 2010 | 08:39 PM
  #64
fostersice's Avatar
fostersice
Now it's all running
What will happen it I fit the ecu with the 300chip on the dark blues that I have fitted unit I find some greens going cheap lol
Old Apr 11, 2010 | 09:54 PM
  #65
martysmartie
Nothing it's just they won't flow as much as greens or equivalent Siemens could so just don't drive it hard otherwise it will be running lean.
Martin
manuel boeckx
13
Oct 3, 2015 02:29 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
