blacktop zetec turbo pistons
hi all where can i get a set of zetec turbo pistons for my zetec turbo build, im using black top rods as ive already had a set, eagle ones, but im using a silver top block, ive been told as long as i use black top pistons i should be fine
so does anyone know some cheap places to get them from?
YES I KNOW I CANT SPELL
the black top rods are longer than silver top rods so if you use pistons/rods that were built for a blacktop and then fit them in a silvertop block the compression ratio will probaly work out high
Try ebay for some JE pistons. Item 180330345421 for example.
