avo coilovers
Old Mar 14, 2010 | 08:14 PM
alirst's Avatar
alirst
Default avo coilovers
right, i have recently bought a frst, its got avo coilovers and has been slammed to the deck by the previous owner.
its so low that the tyres rub the arches on full lock which quite obviously isnt ideal. also i unfortunately live on a hill with umpteen speed bumps up it. so the long and short of it is i want to jack the suspention back up a bit.
so, i've got my c spanner and wd40 but my question is, which way do you need to wind the spring seat to raise it back up?
sorry if this is a stupid question but this is the first car i'v had with adjestable suspention
cheers, ali
Old Mar 14, 2010 | 08:27 PM
DHMC's Avatar
DHMC
I would recommend a professional setup as you could really fuck up the ride (probably no more than currently is!)
Also you have to insure its done on a level ground.
Get them setup professionally
Old Mar 14, 2010 | 09:03 PM
alirst's Avatar
alirst
surely as long as i adjust each unit by the same amount of turns and its on level ground it should still be all straight and level?
Old Mar 14, 2010 | 09:51 PM
Not trying to be sarcastic, just helpful, think about what you are trying to achieve, ie you want a greater distance between the suspension arm and the car body.
The spring is taking the whole weight of the car, this won't alter, so the spring is going to stay the same length, thus as the spring is pushing the car body up it needs to be higher to lift higher as the spring length remember is fixed, so as the collar on the strut faces you, you would need to turn the c spanner to the right, or counter clockwise, if you were viewing from above, make sure you give a good spray, and see if there are any locking plugs in the collar, there usually is, undone with allen key(5mm I think).
Don't worry about getting it pro set height wise, set with a ruler.
The idea of coilovers is so you can corner weight the car if you want to go to the extremes for grip/handling, this is done by putting each wheel on a scale to read the weight of the car at that corner, then if one was slightly lower than the adjacent one, "weight" could be added to the corner by adjusting the coilover(moving spring seat up), of course weight never alters but the way the car sees it does.
Saying that most just get them for the ride heigt adjustability, as you are doing.
Old Mar 15, 2010 | 07:24 AM
alirst's Avatar
alirst
didnt come across as sarcastic at all, very helpful, cheers for the advice
Old Mar 15, 2010 | 07:56 AM
gary fraser's Avatar
gary fraser
+1 cheers tabetha very helpful just bought a set o avo coilovers for my frst to and was unsure how to get the right ride height all round.
cheers gary
Old Mar 15, 2010 | 11:44 AM
No probs matey.
mk1turboestate
Dec 2, 2015 08:31 PM
S3an
Sep 26, 2015 11:39 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
S3an
13
Sep 13, 2015 10:01 AM
Topjoe9
Sep 12, 2015 09:50 AM
