saff cos boost problems
Old Mar 12, 2010 | 08:28 PM
rossimk2's Avatar
rossimk2
Default saff cos boost problems
hi all, newbie on here, some help and advice please,
the car is a 1990 saff cos 2wd, breif spec, l6 330 chip, 3 bar map sensor, dark greens, std turbo new -34 actuator gpa head gasket,mongoose system, gpa filter,rs500 intercooler
the problem i have is that when car boosts any thing over 10 psi it coughs and splutters like mad, ive changed the plugs checked the rotor arm cap and leads coil ect,
any info would be great thanks
Old Mar 13, 2010 | 10:33 AM
Has it had the fuel pump rewired ?, and the fans ?.
If not then do it for safeties sake, could be running out of fuel(pressure) if pump hasn't been rewired, this will kill your engine, a number of other things like the fuel filter needing changing so do this also, unless you know it's new.
There's theads up detailing the fuel pump rewire, a easy job that can make the world of difference, so just hit the search function button.
JK12
33
Apr 26, 2021 12:09 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
RSBryden
Sep 6, 2015 08:39 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
