4x4 header tank
Old Mar 11, 2010 | 09:18 PM
Phil2002's Avatar
Phil2002
Default 4x4 header tank
Right this may sound like a stupid question but i'm gonna ask any way.
can i use 4x4 cossie header tank on a 2wd saff and use the extra in/outlet(circled in red) to go to my swirl pot and keep the water return from the turbo on the smaller inlet at the top?
Please don't laugh and point if i have over looked the obvious.
cheers,
Phil
Old Mar 11, 2010 | 10:00 PM
Toe Knee's Avatar
Toe Knee
you can do whatever u want in theory, u can deff use a 4x4 tank on 2wd but have u seen the size of the outlet from a swirlpot?! Their ususally the same size as the turbo return pipe like the small one ontop..............
Plus i would have thought any sort or return to the tank would have to be above coolant level too?!
Old Mar 13, 2010 | 11:01 AM
The return doesn't need to be above water level in the tank, you could do as you wished no problem.
Nov 1, 2015 06:53 PM
Iain Mac
Sep 30, 2015 09:39 PM
mpilk
Sep 27, 2015 09:21 AM
