disable imobiliser
Old Mar 7, 2010 | 12:27 PM
paul123's Avatar
paul123
Default disable imobiliser
i need to disable the imobliser on my fiesta 1.4 16v r reg how can i do this dont want to go to the expense of replaceing ecu and keys and key pick up thing please help
Old Mar 8, 2010 | 07:00 PM
steve4i's Avatar
steve4i
whats the problem making you wanting to remove it?
Old Mar 8, 2010 | 07:08 PM
fraser9764's Avatar
fraser9764
not the best method, but remove the red bit from the end of your key and tape it to the ignition barrel.
Old Mar 8, 2010 | 08:16 PM
paul123's Avatar
paul123
the imobiliser keeps kicking in when cold so i cant start the car i have been told it would cost 1000 to have it sorted because it would need ecu, key traciever, barrel ,and all sensors replaceing , the car is thirteen years old it is a good runner when it starts like i said it only happens when it is cold once started which can take up to two hours my latest way of starting it is to heat the inside of the car with a blow heater i think ecu may have a short or dry joint and the heat is may be expanding it this is why i want to disable imobiliser but have been told it cannot be done
Old Mar 8, 2010 | 08:17 PM
paul123's Avatar
paul123
thanks will give it a go
Old Mar 10, 2010 | 04:41 PM
paul123's Avatar
paul123
can i put my question another way is there any sensor under the bonnet that would make the imobiliser kick in and the car not to start it was in the sun today and started first time i am thinking may be air in take or water temp sensor
Old Mar 10, 2010 | 04:48 PM
mercgrey's Avatar
mercgrey
no not really! does the red light stay on/ if not id say its the crank position sensor or just faulty coilpack
Old Mar 10, 2010 | 05:53 PM
steve4i's Avatar
steve4i
when you say it wont start, does it actually turn over or just the ignition lights come on and when you try to crank, then it wont do anything?
Old Mar 10, 2010 | 06:48 PM
paul123's Avatar
paul123
yes it wont turn over but ignition lights come on and little imobiliser light flashes rapidly but when it is warm all is well starter works ok this has been tested i there fore think it is not ecu what are the symptoms for faulty crank sensor
Old Mar 10, 2010 | 07:52 PM
steve4i's Avatar
steve4i
could possibly be a faulty transponder around the ignition barrel or an ignition control module?
if it was a faulty crank sensor the car would just turn over as normal but not fire as it wouldnt send a signal to the Coil pack to give a spark
Old Mar 10, 2010 | 09:08 PM
mercgrey's Avatar
mercgrey
as above could be transponder ring, modual ecu or even yust broken chip in the key maybe?? do you have the red key? or a spare to try?
Jim Galbally
21
Feb 8, 2006 07:45 PM
ossie cossie
Ford Escort RS Cosworth
Jan 27, 2006 06:56 AM
TUBZ
Fiesta RS1800/RS Turbo
Apr 16, 2005 10:47 PM
DaveEscos
Feb 11, 2005 11:33 AM
davie0146
Sep 30, 2004 07:59 PM
