Gearbox
Old Mar 3, 2010 | 07:03 PM
S2Steve's Avatar
S2Steve
Default Gearbox
On over run in 1st and 2nd it gives off a scratchy squeel, do they often lose oil? Can I check that? Or is it going to die and I should be hunting for a new one?It's an RS turbo by the way.
Cheers!
Old Mar 3, 2010 | 07:05 PM
liam-rst's Avatar
liam-rst
shit happens
that will be another 1 with a fucked diff then
Old Mar 3, 2010 | 07:21 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
diffs rarely fail pal, i'd be more concerned with the shafts inside and gearsets.
just check engine mounts to make sure it's not the alternator hitting crossmember.
Old Mar 3, 2010 | 08:09 PM
S2Steve's Avatar
S2Steve
If it was that why would it only happen in those 2 gears? The ratchet on the clutch pedal needs changing, don't suppose something small like that could cause the problem?
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
