t2 help needed
Old Feb 28, 2010 | 05:26 PM
taittsierra's Avatar
taittsierra
Exclamation t2 help needed
hey just wanting to no how the bearing housing cos apart from the exhaust housing.??rhanks>evan
Old Feb 28, 2010 | 06:15 PM
taittsierra
anybody have any idea??need to replace oil seals>evan
Old Feb 28, 2010 | 06:25 PM
mercgrey's Avatar
mercgrey
5 nuts on the compressor housing iirc, but you will need to get it ballanced again after a rebuild or it will morethan likly distroy itself after a while
Old Feb 28, 2010 | 06:29 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
the answer to the question is lots of hard taps around the core to split it from the exhaust housing. don't go too much on one side as it could damage the exhaust turbine blades.
as said though it may need balancing, just mark the nut/shaft and wheel with a scribe and it should be fine when put back together, maybe the tiniest bit out of balance.
Old Feb 28, 2010 | 06:42 PM
taittsierra
it is sitting loose an i can turn the bearing houseing but it just wont pull apart from the exhuast houseing??>evan
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
