4 x 4 Transmission
Old Mar 12, 2004 | 10:08 PM
Default 4 x 4 Transmission
Right, I am thinking of making an offer soon on a Saphire tractor but as I have always been a rwd drive man, I need to know how the Ford system works.
Am I correct in thinking that it does not (as standard) use trick diffs and torque splitting between axles?
Is it a fixed split, say 30% front 70% rear?
Also, when tuned to 400+ hp can you drive it like a rwd or do you have to make a quick lift mid corner to tuck the nose in? (Proper technical drivers please rely to that one)
Could a company like Zoo Motorsport set the car up not to understeer does anybody know?
Quite a few questions there but would appreciate any replies.
Thanks in advance
Old Mar 12, 2004 | 10:16 PM
PJay's Avatar
PJay
IF tuned to 400bhp the gearbox will die, 4x4 gearboxes are very weak BUT it is a fixed split 60/40 iirc and a quick lift mid corner will probably kill ya
Old Mar 13, 2004 | 12:25 AM
34/66 actually if you wana be picky lol.
Old Mar 13, 2004 | 12:28 AM
PJay's Avatar
PJay
Cheers matey, i knew it wasn't exactly 60/40 but couldn't remember
Old Mar 13, 2004 | 07:22 AM
Hmmm, not happy about the weak gearbox. The good thing about the T5 is that they are cheap as chips and so when they go it isn't a major drama.
Like the flippancy reference lifting mid corner but I am referring to driving on the track where it isn't an issue (had an Impreza 5 years ago)
Maybe I'll stick to the original plan of a proper car then but will take decision under advisement
Any other comments?
Old Mar 14, 2004 | 07:44 PM
markk's Avatar
markk
simple case is
dont bother with 4wd if you are a real driver with good power , unless u got stacks of cash !!
Old Mar 14, 2004 | 11:15 PM
richm's Avatar
richm
depending how you set up the suspension, it is likely to ultimately err towards understeer.. and yes, a quick lift will tuck the nose in
You'd best be awake when you do it though, as you will appreciate, it's a fine line.. I've seen the grass at Castle Combe as a result of not really paying enough attention in the process.
Old Mar 15, 2004 | 10:52 AM
Hmmmmmm, RWD then. we all know only girls and poofs drive 4wd and I'm neither...............at least I don't think so
Only kidding for all the men out there driving tractors
fordjames
Ford Focus Diesel
Sep 3, 2015 10:20 PM
Old ford
Jul 31, 2015 06:50 AM
JAP CRAP
32
Mar 3, 2005 05:24 PM
Rich@rd
15
Jul 15, 2004 09:26 PM
