Help!!! EFI OFAB No spark or tacho?
Old Jan 27, 2010 | 06:12 PM
cabbykarl's Avatar
cabbykarl
Question Help!!! EFI OFAB No spark or tacho?
ok, i'm pulling my hair out.. went to pick kiddy up from school and on the way car dies. I thought maybe it had just stalled so bumped it off whilst still doing about 20mph. However I noticed that the tacho needle was flat on zero ie didn't even move. Even when starting the car normally i'd see it raise to a couple of hundred rpm or so.
Anyway, took a lead off and hooked up a spare sparkplug and no spark. The coilpack connector had the usual 12v across all three terminals and cranking dropped either coilside as i'd expect to see on my analogue meter. Never had a prob with the cps and the wiring to it seems in great condition too.
So I thought maybe EDIS is faulty, tried a known working one, same result.
So I thought maybe coilpack faulty, tried a known working one, same result.
Of course this all happens after 5pm so it's dark and continuity testing just isn't gonna happen tonight. Plus the place where i've left the car makes the Chatsworth estate look posh....
Any ideas? I just haven't ever seen the tacho fall flat like that before so maybe it's something someone on here might be able to shed some light on?
Thanks for reading,
Karl.
Old Jan 27, 2010 | 06:37 PM
JonathanJ's Avatar
JonathanJ
Had exactly the same issue with mine and it was the cps , there is a later one with gold connectors , and also found mine was loose , only slightly but was enough , as soon as it was taken out , cleaned , refitted it worked .
Just a thought
Old Jan 27, 2010 | 06:49 PM
cabbykarl's Avatar
cabbykarl
yeah I was worrying about that. i'll still check all connectors back to the ecu in the daylight though. Thanks.
Old Jan 27, 2010 | 07:53 PM
I would also go with the cps, as a first thing to really look at in detail.
Old Jan 27, 2010 | 07:59 PM
cabbykarl's Avatar
cabbykarl
Yup shall do, thanks again for the replies
At least a kind friend towed me home.
Old Jan 28, 2010 | 09:21 PM
cabbykarl's Avatar
cabbykarl
Just to let you know I found the problem today. Turned out to be the ground wire off EDIS pin 9 had shorted with a 12v cable and burnt away. Took a while to find it!
Thanks again for the replies though. At least now I know that if an EFI tacho drops to zero and stays there i'll check the EDIS power + gnd 1st!
CheeRS
Karl.
Old Jan 29, 2010 | 11:21 AM
Thanks for posting up result, will help more people in future.
DixieTheKid
11
Jun 6, 2020 11:20 AM
mk1turboestate
Dec 2, 2015 08:31 PM
deathrider666
Sep 28, 2015 06:12 PM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
