fiesta starting problems like it wont ;-)
Old Jan 16, 2010 | 01:30 PM
jontheplank's Avatar
jontheplank
Default fiesta starting problems like it wont ;-)
Hi there i have recently bought a 1.25 fiesta 2000my as a non runner with a blown headgasket with no compression on 3 cylinders - i have repair that fualt no problem including skimming the head but it wont start (did not before i bought it ) i have plugged in 2 scan tools in and both have come up link error so im gussing need another pcm ? there is spark and fuel getting through any ideas would be welcmed ps i have looked through your archive for an answer but cant find one?
thanks in advance jon
Old Jan 16, 2010 | 09:25 PM
saph_Al's Avatar
saph_Al
i assume u now have compression on the above cylinders ? if ur sayin that 2 different scanner wont read then surley u have to be askin why . is it the correct ecu for the car? is there even an ecu there ? is the ecu reading the key ok ? is the fuel comtaminated ? exhaust full of water ? air box clear ? all plugs clean properly connected and dare i say where they should be ?. Earths ?
Old Jan 16, 2010 | 10:00 PM
martysmartie's Avatar
martysmartie
Is the fuel actually reaching the cylinders, I.E injectors working ok? Is the EML light on dash?
Was the engine timed up ok when reassembing?
Martin
Old Jan 17, 2010 | 08:27 AM
jontheplank
thanks for the replys
saph_Al
1.compession fine
2.how do i know the ecu is correrct for model? it is a mk5 ecu and the key turns off the imobilizer
3.not checked the fuel is not contaminated good thought !
4.no water in exhaurst
5. air box and plug leads all ok
6.earths were my only other thought but fuel pump runs fine as does coil pack -spark to all 4 cylinders- turns over nice and fast -my have another root around for other earths i have missed
martysmartie
1. fuel reaching cylinders as took out plugs and they were wet
2.eml light not on
3.engine timed with correct laser zetec timming kit
i was only thinking that the ecu may be at fualt maybe got damp as the wiring loom goes through the top of the bualk head through a large gromet
to the ecu and the ecu sits 6 inches below the gromet (very clever design) to is in the right place for a soaking!!
Old Jan 17, 2010 | 05:04 PM
martysmartie
If you had no ECU present you would have no spark or fuel at all! When you turn the ignition on does the fuel pump prime? The immobiliser must be ok as you have a spark, are the plugs in good condition?
Martin
Old Jan 19, 2010 | 05:33 PM
jontheplank
Hi martin thanks for the reply yes the plugs are new gapped to 1.3mm as per ford manual ? yes fuel pump primes it sort of feels sometimes like it wants to start so have bought a crank sensor today as i have found these sometimes go hope that will sort it !!
thanks jon
JoeyBoyden
Jan 4, 2024 02:36 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
