mk6 2k jitters
Old Jan 12, 2010 | 03:06 PM
Amccormack's Avatar
Amccormack
Default mk6 2k jitters
hi
got myself a ford escort mk6 while im driving around town and on motorways i get a stutter while hitting the 2k range but once past 2.5k it stops what could be causing this? new plugs and leads on last service
Old Jan 12, 2010 | 06:11 PM
Mark_'s Avatar
Mark_
check the engine loom multiplug hasnt come adrift,
its the big plug on the bulk head just behind the inlet plenum,
had this happen on mine and known of a few others its happened on.
also remove the sparkplug cover and check both the wires that go to the coil packs,
these always brake up due to the heat build up under the cover and cause all sorts of running issues,
id replace these as a matter of course.
you should replace all the filters and plugs as a matter of course if you dont know when they were last changed.
Old Jan 12, 2010 | 06:15 PM
BlairM's Avatar
BlairM
Can also be the Mass Air Flow sensor, seen these let go on a few cars. I'm sure on my brothers GTi, his mechanic mate said remove the electrical connection to it, if it runs fine thats your problem.
Old Jan 12, 2010 | 06:18 PM
Mark_'s Avatar
Mark_
there isnt a mass airflow sensor on the rs2000's
Old Jan 12, 2010 | 06:21 PM
Amccormack's Avatar
Amccormack
forgot to mention its the 1.8 16v model not rs2000 but i think my maf is ok as when i unplug it the car nearly stalls indicating a change has been noticed by the car
Old Jan 12, 2010 | 06:26 PM
Mark_'s Avatar
Mark_
its the title, mk6 2k.
i thought you meant rs2k
Old Jan 12, 2010 | 06:30 PM
Amccormack's Avatar
Amccormack
yea i know im a tit i ment 2k rpm
rex647
Mar 6, 2022 06:20 AM
Chopshop85
Oct 22, 2015 09:26 PM
Vacuman
Sep 22, 2015 12:09 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
