2wd cossie no boost
Old Jan 5, 2010 | 07:20 PM
1cosworth's Avatar
1cosworth
Default 2wd cossie no boost
2wd cossie ( blue inj 2.5bar map) wont build more than 1bar .any ideas people
Old Jan 5, 2010 | 08:16 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
actuator on it's way out?
try bleeding some air off the actuator or giving it more pre-tension.
if that doesn't sort it, then it seems ecu/amal related.
Old Jan 6, 2010 | 10:47 AM
martysmartie's Avatar
martysmartie
Is the amal clicking if so these fail and this is what they do? gurantee that's what it will be, to confirm unplug the amal valve and go for a drive if same boost then amal valve is not working.
Martin
Old Jan 6, 2010 | 12:13 PM
1cosworth's Avatar
1cosworth
eeeee i dont have amal valve .just a pressure regulator in the solenoid between the actuator and the turbo housing
Old Jan 6, 2010 | 01:09 PM
Alvyn's Avatar
Alvyn
MORE info needed ie has it just started doing this??
Old Jan 6, 2010 | 01:24 PM
martysmartie
It would have done, explain what you mean by solenoid between the actuator and the turbo housing as a amal valve is an electronically controlled solenoid, screwed by two screws into the intercooler? If you don't have that you will have a bleed valve which is not a solenoid.
Martin
Old Jan 6, 2010 | 01:27 PM
rog's Avatar
rog
Boost leak thru a hose, Worn turbo, Leaking wastgate, have you tested the actuator spring?
Old Jan 6, 2010 | 03:27 PM
1cosworth's Avatar
1cosworth
i ve just check the hoses no leak there yes it is a bleed valve(κλεφτης in greek).i tryed an new actuator and seems to boost fine.thanks people
JK12
33
Apr 26, 2021 12:09 PM
markk
Sep 9, 2015 08:11 AM
jc1989rs
Sep 5, 2015 08:09 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
