Core plugs!
Old Dec 26, 2009 | 12:28 PM
eoeumc's Avatar
eoeumc
It's ALIVE..Well sort of!
Question Core plugs!
Hi there all
Hope you all had a good Christmas?
I am looking ofr some info on the core plugs. I have just found out that my engine has a huge hole in the front and one of the plugs are missing
What would cause this and would there be any other damage to something else due to this or is something knackered to make the plug come out (like frozen pipes) ??
My car was frozen up but the car wasn't started or even tried to be started while it was frozen. Its just that I filled the water bottle up and it satyed in there. When the car defrosted it was empty and when I filled it up the pissed out of the front from the missing core plug hole
Cheers peeps
Old Dec 26, 2009 | 04:35 PM
Alvyn's Avatar
Alvyn
the core plug's popped out due to the water being frozen(why didn't you empty the water out prior to the freeze or fill up with antifreeze)??? YOU may well be lucky that it just a case of refitting a new core plug and away you go!
Old Dec 26, 2009 | 06:16 PM
eoeumc's Avatar
eoeumc
I have had the car for about 3 weeks now. It has not moved off of my drive or been started up at all yet. I put some water in the car as the bottle was empty before I tried to start it. The water stayed in the bottle then I was going to start it. It didn't start and then the freeze came Hence why I have a core plug missing!
What else could the freeze of done then?
Old Dec 26, 2009 | 06:18 PM
GTi-R23's Avatar
GTi-R23
The ladies love it French
Cracked the block as a worst case scenario, but the whole point of the core plug is to prevent this from happening.
Should always use plenty of anti-freeze at this time of year.
Old Dec 26, 2009 | 09:57 PM
eoeumc's Avatar
eoeumc
I will use antifreeze but just didn't as I thought there would be a leak and the water would just go straight through
Old Dec 27, 2009 | 10:39 AM
Toe Knee's Avatar
Toe Knee
as above, worse case is that it cracked the block as water expands as it freezes. Know what u mean about just using water to check but as said in winter full stop you dont want to leave just water in it!! next time undo a pipe on the rad/engine so that u drain out as much water as poss.
Old Dec 27, 2009 | 12:29 PM
Despite what people think, the core plugs were never fitted to stop damage from freezing water, they were to release gasses created when casting, but protecting the block is a bonus.
The freeze hasn't been too bad, I think you will be ok, only one way to find out anyway.
Old Dec 27, 2009 | 10:03 PM
eoeumc's Avatar
eoeumc
Thanks for the votes of confidence. I just hope its going to be an easy one to sort out. But I am not normally that lucky But maybe there will be a first time lol
Old Dec 30, 2009 | 12:08 PM
yogi's Avatar
yogi
hope the rear one to the bulk head, hasnt gone either,, engine out job
Old Dec 30, 2009 | 05:07 PM
eoeumc's Avatar
eoeumc
Only found one lying on the floor today
Fingers are still crossed lol
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
