leak and high idle
Old Dec 14, 2009 | 05:45 PM
griffo69's Avatar
griffo69
Default leak and high idle
evening everyone, i have a leak which i found coming from the drivers door seal, i replaced the seal with another 1 from a escort but it still the same. water just runs over the top of the seal, its had a sill and rear quarter fitted by a previous owner, is it possible its not meeting the door as it should.
also when i start the car it idles at 1800-2000 revs. no air leaks on the hoses , sometimes if i pull the throttle cable the revs drops to near normal. ive recently changed the injectors could it be coming from there
cheers
Old Dec 14, 2009 | 06:46 PM
zetecdan's Avatar
zetecdan
sounds like the throttle cable is sticking.
did you refit it correctly if you had to remove it to do the injectors.?
Old Dec 15, 2009 | 05:27 PM
griffo69's Avatar
griffo69
hi mate i didnt move it to fit injectors. could i have done something to it when i did fit them
cheers
timsrs
Nov 13, 2018 11:48 AM
fordrallycar
Sep 30, 2015 07:57 PM
Fudgey
21
Sep 30, 2015 06:19 PM
