escort van advise trouble starting
Old Dec 8, 2009 | 08:59 PM
jono55d's Avatar
jono55d
Default escort van advise trouble starting
hi, im looking for some help with my escort van. it just turns over without starting and eventully it does but then dies again. ive cracked off the injector pipes and there is fuel getting through so now im stumped. ive only had it for a week but its been fine up till now. any help would be great
Old Dec 8, 2009 | 09:04 PM
pani_k's Avatar
pani_k
PassionFORD Member
Glow plugs? It really is getting pretty cold out there.
Old Dec 8, 2009 | 09:09 PM
forevaford's Avatar
forevaford
glow plugs
Old Dec 8, 2009 | 09:10 PM
jono55d's Avatar
jono55d
whats the best way of testing them? sorry in not much of a diesel man lol
Old Dec 10, 2009 | 08:13 PM
crazyshad1's Avatar
crazyshad1
rest the thread of the plug on 1 of the terminals of a car battery, run a length of wire from the other terminal of the battery and touch the end of the glow plug with the end of the wire, should start to glow red if not then its f*****. glow plugs dont explain why its cutting out, could be fuel pump fault?
Old Dec 12, 2009 | 08:22 PM
cozzy jeff's Avatar
cozzy jeff
instead of trying to start the car as soon as the glow plug light goes off wait till you here a click from under the bonnet this will be around 10 seconds,if your plugs are working this will help.put a multi metre on the glow plug and to earth then turn the ignition on to make sure your getting power to the glow plugs.
Old Dec 12, 2009 | 08:25 PM
cabriolet's Avatar
cabriolet
take the nuts off the glow plugs remove the wiring take a wire from plus side of battery touch each glow plug in turn if it sparks the glow is fine check the master fuse up by the battery they dont blow normally just fall apart my money is on filter housing fella
Old Dec 24, 2009 | 08:30 PM
dan_m2k's Avatar
dan_m2k
I'm having a similar problem with my 1.8D (non-TD) van... got the battery charged and checked there's fuel at the injector, but it's just churning over and over.
The glow-plug light comes on and then goes off, and I've tried leaving the ignition on for a little longer... but she still won't fire up. I don't notice a clicking from the engine at all?!
Where is the glow plug relay/glow plugs, please? Could do with getting it moving again sometime this year...
Old Dec 24, 2009 | 08:42 PM
Alvyn's Avatar
Alvyn
check the glow plugs main big fuse near the battery is still intacked!
Old Dec 24, 2009 | 09:15 PM
dan_m2k's Avatar
dan_m2k
thanks -- like on the passenger side front wing or in the battery bay?
there's a single inline fuse holder that was attached to the battery that's never had a fuse in it, but i figured this was for the towbar or something?
TIA
Old Dec 24, 2009 | 10:16 PM
Alvyn's Avatar
Alvyn
TIA
right next to the battery should have a couple of BIG fuses in it the one your after is red(their usually corroded across the pin)
Old Dec 27, 2009 | 11:10 AM
dan_m2k's Avatar
dan_m2k
Got it, thanks, the big red fuse (right on the battery) was fine... Tried it with a continuity tester and seems alright.
Can anyone point me in the direction of where to look for relay/glow plugs now please?
Old Dec 27, 2009 | 11:39 AM
Alvyn's Avatar
Alvyn
glow plugs are at the front of the engine joined together with a piece of wire running across the tops of them x4!
Old Dec 27, 2009 | 11:46 AM
cozzy jeff's Avatar
cozzy jeff
glow plug relay is on the passenger side inner wing large black one,according to the haynes manual ford did change the relay to a one that operates the glow plugs for longer, mite be worth checking that yours is the never version,have you taken a glow plug out to check if its working direct off the battery be careful as they do get really hot.if glow plugs arnt at there best it will certainly show in this cold weather.
Old Dec 27, 2009 | 01:02 PM
dan_m2k's Avatar
dan_m2k
That's my next stop -- now I think I know what I'm looking for! I think I've identified the relay but on tracing it I can't seem to see anything obvious that looks glow plug like.
Thanks for all the help guys. I'm out of clues when it comes to derver's!
Old Dec 27, 2009 | 01:48 PM
cozzy jeff's Avatar
cozzy jeff
can you see the red wire running horizontal at the bottom of this picture?this is the feed that links the glow plugs.
Old Dec 28, 2009 | 02:21 PM
cozzy jeff's Avatar
cozzy jeff
did you manage to find them?heres a pick to help you out.
Vincereese
Jun 1, 2023 09:14 AM
Bailes1992
Aug 16, 2015 07:14 PM
Vincereese
Aug 16, 2015 06:38 PM
Zoggon
Aug 10, 2015 10:39 AM
vdubo7
Aug 2, 2015 08:17 PM
