fitting a mega squirt to blacktop
Old Dec 2, 2009 | 09:42 PM
alex_666's Avatar
alex_666
Default fitting a mega squirt to blacktop
hi all basically im looking at a ms ecu for my 1.8 focus as its going to be on itbs soon!
i need help with wiring it up what sensors need wiring?
ive got basic wiring knowledge and if some one had some wiring diagrams it would be great help! ive also got a spare engine with most the sensors in place as well so can use them if need be. whats this edis system i keep reading about? do i need that?
alex
Old Dec 3, 2009 | 11:38 AM
zok's Avatar
zok
I recommend you to use an Autodata - this software has many wiring diagrams for engine management, troubleshooting tips, how to test sensors, etc...
Old Dec 3, 2009 | 11:43 AM
Raj_FRST's Avatar
Raj_FRST
Half Rice Half Chips
give matt at Mtech a shout, he is the daddy with MS and has also manufactured MTECH's own ecu, the V4
hope this helps mate
Raj
Old Dec 3, 2009 | 04:42 PM
rich123's Avatar
rich123
hay there dale can set the whole lot up for u if u want http://baileyperformance.co.uk/ and his prices wont cost u the earth i think its around the 600.00 mark for fitting and mapping the ecu give him a ring and see what he can do for u
Old Dec 3, 2009 | 06:10 PM
alex_666's Avatar
alex_666
tbh lads im looking at doing it my self, well the wiring and base map then theres a place by me that will do the final map! just looking for info on what sensors need wiring.
alex
Old Dec 10, 2009 | 02:40 PM
intergrale30's Avatar
intergrale30
Look at www.mtechautomotive.co.uk they have the diagrams on there site
Old Dec 10, 2009 | 02:50 PM
JesseT's Avatar
JesseT
To actually answer the question, you will need the following sensors:
Crank position sensor (standard on the block reader the flywheel)
Engine temperature sensor
Air temperature sensor
Throttle position sensor
MAP sensor (built in the Megasquirt)
EDIS is Ford's ignition management module that is compatible with Megasquirt. This was used on all early Zetec engine before the module was integrated into the main ecu.
Old Dec 10, 2009 | 03:02 PM
alex_666's Avatar
alex_666
cheers jesseT has any one got a wiring diagrams for a zetec?
alex
Old Dec 11, 2009 | 09:53 AM
M-Tech Automotive's Avatar
M-Tech Automotive
Alex,
Whats the year? I can post up a pin-for-pion wiring diagram for it.
Cheers,
Matt
Old Dec 11, 2009 | 09:59 AM
M-Tech Automotive
Youn wont technically need/able to use the MAp sensor as with ITBs you want to map with Alpha-N (unless you plan on having a big plenum chamber)
othewise as per JesseTs post:
Coolant
Air Temp (you will need to add this sensor as standard it is part of the AFM)
TPS
Crank
If you use our V4 you wont need EDIS modules or anything like that as ours as coil drivers built in. Also, it supports all the standard Ford sensors, so the only additional you will need is air temp, which we can supply if needed for about Ł12.
The V4 also has a tacho output etc so your dash will still work, and programmable fan output (the fan is ecu controlled on the focus, unline fezzies, RSTs etc that use a stat switch)
We also have an array of basemaps for the Zetec. Are you running jenvies or GSXR itbs?
Matt
Old Dec 11, 2009 | 10:32 AM
M-Tech Automotive
Just created:
http://www.mtechautomotive.co.uk/gui...00Focus18Zetec
Matt
Old Dec 11, 2009 | 03:02 PM
alex_666's Avatar
alex_666
Originally Posted by M-Tech Automotive
Alex,
Cheers,
Matt
alright mate mines an 03.
on that link you posted up were for exmaple it says
ground and gives 4 numbers and then on the ms ecu its got 8 numbers do you have to basically fit all 2 wires off each lead from the ecu and one into each ms ecu?
and the same for the ignition were theres 2 wires on the ecu going into one on the ms? is that correct?
also on my tps sensor i have 3 wires and theres only one on the table you put up do i only need to use the one then?
alex
Old Dec 11, 2009 | 03:07 PM
alex_666's Avatar
alex_666
Alex,
Cheers,
Matt
alex
Old Dec 11, 2009 | 03:23 PM
M-Tech Automotive
Alex,
Yes the grounds should all be linked together. Anything wheres theres more than one wire links to all the others etc.
The TPS has a ground connection (pin 46 on ECU) which we take car of by connecting to the grounds listed before hand.
TPS Signal is pin 47,
TPS Vref is pin 26
You will also need to ground pin 32 which is the starter motor relay (PATS start inhibitor)
Cheers,
mattr
PS, our V4 isnt an MS :P Its an M-Tech
Old Dec 11, 2009 | 03:26 PM
alex_666's Avatar
alex_666
Alex,
TPS Vref is pin 26
Cheers,
mattr
will the wiring still work for a mega squirt 2 ecu?
does INJ mean injectors btw?
alex
Old Dec 11, 2009 | 03:34 PM
M-Tech Automotive
INJ is injectors yes...
The pins will differ for the ECU as the V4 uses a proper plug :P
Matt
Old Dec 11, 2009 | 08:21 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
piece of piss mate, you need to throw an earth to the sensors and a feed wire to the ecu, thatt's the air temp and coolant sensor, crank position sensor needs a screened cable, earth one wire and signal wire to ecu.
injectors need a wire from the driver from ecu to one pin and live feed to the other, you can use batch firing where 1+2 and 3+4 fire together each cylce or sequential which is a little rare in use due to the complexity.
coil can be driven directly off the ecu, so forget edis as it's crap in comparisson. that's two wires from ecu and a live feed to the centre pin of the coil.
then you've got the throttle position sensor which is only three wires, 12v, 5v and earth IIRC.
just idle valve after that and you can chose how to control that, only one wire from ecu and one live wire to it.
lambda sensor, wideband recommended, still only one wire to ecu though.
pretty much it to be honest.
if you've not done it before you'll make mistakes and probably hit a brick wall, remember getting it started is the hardest bit, but with a little practise it's pretty easy.
Old Dec 11, 2009 | 09:42 PM
M-Tech Automotive
Its 5V, hround and signal to ECU on the TPS That mistake would kill most ECUs....
Old Dec 11, 2009 | 10:13 PM
alex_666's Avatar
alex_666
cheers m-tech and xr2wishy! been a great help! just need to get my ecu now!
alex
Old Dec 12, 2009 | 12:33 PM
M-Tech Automotive
You know where we are lol
Old Dec 12, 2009 | 03:45 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
get the better one you can afford, at least the msIIv3.0, it's what i'm running and pulls very well.
errrmmm, yeah 12v to tps would kill it lol!
tired when typing.
nowt wrong with M-tech so i've heard these days, no experience myself so won't comit eitherway in the M-tech slagging on efiextra.com, as far as i'm aware that was bad builds a long time ago.
Old Dec 12, 2009 | 04:10 PM
M-Tech Automotive
XR2,
Indeed it was nearly 4 years ago now! And its not anywhere near as bad as they make out, they just they can't handle the competition!
Our V4 runs (as an option) MS2 Xtra, so you get all the features your after with a better case, fully featured better built ISO9001 ECU..
We also gvie you one hours free dyno time, which cant be bad...
Matt
Old Dec 13, 2009 | 02:33 AM
pdfbt40's Avatar
pdfbt40
So does a V4 have an EOBD data stream output as used for the Focus and all the 'electronic' dashed Fords ?
Old Dec 13, 2009 | 09:18 AM
M-Tech Automotive
No, but we have got round it before
Old Sep 28, 2011 | 07:32 PM
kevin buchan's Avatar
kevin buchan
sorry to jump in here,ive bought a msv3 ecu along with tbs second hand to put on my 2.0 zetec,wired up as per diagram,nothing opened up ecu and found 3/4 of megasquirt board assembled with additional capacitors and resisters soldered on,looks professional so don,t think ive been bumped,question is does anyone have any idea of ms adaptions etc because i followed ms wiring anyway ,but no spark,any ideas
Old Sep 28, 2011 | 08:09 PM
pdfbt40's Avatar
pdfbt40
If its a MS-I V3 (pcb) then the bottom left of the board is a patch area for various options like 'shift light'. I've also seen it used for the second spark driver instead of mounting on the main heat sink !!
The only easy way to test the ECU configuration is a Stimulator, preferably the Jim Stimulator. Once you know the hardware and software are correct, then move on to the actual Zetec installation.
Martin
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
ekjim
Aug 27, 2015 05:20 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
