cossie suddenly it started to jerk?!
Old 21-11-2009, 08:06 PM
cossie15
cossie15's Avatar
Default cossie suddenly it started to jerk?!
was driving the cossie the other day and suddenly it started to jerk, sounded like its low on fuel. Anyway it then sounded like a subaru impreza, that deep engine sound, its hard to explain. Any ideas???? check all plugs, leads etc but not default found.
Old 21-11-2009, 08:13 PM
fatmike
fatmike's Avatar
Basically it was running on 3 cylinders. If plugs and leads are ok, could still be loads of things mate. Dizzy, coil.... Have you got a group a coil on there?? always worth having.
Make sure the crank position sensor is in good working order and is not covered in crap/ and or old and shabby.
Take dizzy cap off and make sure there is no water or crap in there, check overall condition of the dizzy and the points in the cap.
Worst comes to worst could be a blocked injector....
The list goes on..
Old 22-11-2009, 12:20 PM
It won't be the crank sensor as it would not fuel at all if this was not signalling.
Try pulling the plug leads off one at a time to identify the affected cylinder if you think it's running on 3, then you swap the lead with another and see if the problem moves to the cylinder with the suspect lead, if it doesn't the leads are ok.
This leaves fuelling as most likely, or a duff plug, again can do swappsies with the plugs.
SmudgerByName
52
28-07-2016 06:14 PM
RSmark84
20
24-08-2015 02:17 AM
tommylommykins
Ford Fiesta
08-08-2015 08:01 PM
sridgett
15
03-08-2015 07:26 PM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: cossie suddenly it started to jerk?!
