Mk 4 RS cab engine probs
Old Nov 20, 2009 | 09:45 PM
eoeumc's Avatar
eoeumc
It's ALIVE..Well sort of!
Question Mk 4 RS cab engine probs
Hi there all
How easy is it to change a head gasket on the RS engine? Also what sort of costs would I be expecting to pay to do it (parts mailny)?
Cheers peeps
Old Nov 20, 2009 | 10:07 PM
RSargie's Avatar
RSargie
depends really, if you not running to much boost you can get head set and bolts for about Ł30-40 from locql motor factors. you will need the head skimming as well that will cost between Ł30-40 and then you want to put it back together with a new belt Ł25 and give it o+f, plugs and air filter. just remember "cleanliness is next to godliness". make sure everyhting is clean and traces of old gaskets, sealants is removed before you put it back together.
Old Nov 21, 2009 | 11:30 AM
It's probably about the easiest hg you could do, the head may not need skimming, check with torch and straight edge first.
yorkie92
27
Sep 22, 2017 05:56 PM
carlo
24
Oct 5, 2015 08:20 PM
ray barker
Aug 7, 2015 09:00 AM
slammedorion
21
Aug 6, 2015 11:38 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
