speedo not working
Old Nov 12, 2009 | 09:57 PM
alicos's Avatar
alicos
Default speedo not working
does anyone know a good cosworth macanic in the south london area thanks
Old Nov 12, 2009 | 10:42 PM
Alvyn's Avatar
Alvyn
1 speedo cable snapped
2 speedo clock knackered (doubt it's this tbh)
3 speedo drive in the box is knackered!
Old Nov 13, 2009 | 09:43 AM
alicos's Avatar
alicos
thanks alvyn do you know anyone in london area who
could fix it
Old Nov 13, 2009 | 12:58 PM
martysmartie's Avatar
martysmartie
Depending where in London you are I could have a look for you? As said 99% will be the cable
Martin
Old Nov 14, 2009 | 03:00 PM
There is as said a very good likely hood it is the cable snapped.
Some replacement cables have a inner that is slightly too short, as it only engages around 3mm - 4mm in the gearbox drive part, despite the hole there being over 1"(25.4mm) deep, I found this on the last few cables I did, but supplier/maker was told, and said added 5mm.
Old Nov 15, 2009 | 09:05 AM
alicos's Avatar
alicos
thanks tabetha i will check it out
Old Nov 15, 2009 | 09:08 AM
alicos's Avatar
alicos
hello martin i live in croydon i could drop the car off if that would suit you cheers
Tinshaw
Aug 4, 2015 09:16 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
Escortdriver1
Jul 31, 2015 02:36 PM
