Fiesta Engine loom re-wiring.
Old Nov 7, 2009 | 11:17 PM
fordwithapassion's Avatar
fordwithapassion
Default Fiesta Engine loom re-wiring.
Hi there, this is my first post on the forum. Thanks to some rather large rodents making a nest in front of the bulkhead in my P'reg fiesta,and chewing through a lot of the wires in the engine loom, I unfortunately have to rebuild it ,the loom that is. It would have been a fairly simple task to just rejoin most of them, but the majority of the wires that are broken are black, ignition wires I presume?, and this makes it slightly more difficult. If anyone could send me a copy of a wiring diagram, for the engine loom of a P'reg ford fiesta 1.4 with endura written on the rocker cover, I'd be very grateful.
Old Nov 8, 2009 | 02:55 PM
Black on a ford is a switched live, have they just eaten the insulation or broken the strands as well ?
TVR's are always having their looms eaten as well by mice/rats etc!!
Old Nov 9, 2009 | 04:22 PM
fordwithapassion
The strands have been completely chewed through, save for two black wires. At least four of the wires end up at the injectors, while the others are for the alternator.
Old Nov 9, 2009 | 04:43 PM
The only way out then, without spending mega bucks is to go all the way back till you can see wire colour, at each end and rejoin.
Old Nov 11, 2009 | 10:53 AM
fordwithapassion
I see, in order for me to trace the wires will the dashboard have to come out for me to gain access to the ecu?, im not entirely sure where it is on a fiesta.
Thanks in advance.
Old Nov 11, 2009 | 10:56 AM
JEEMO's Avatar
JEEMO
i guess its a Mk4 fiesta?
Old Nov 11, 2009 | 07:14 PM
fordwithapassion
You are indeed correct JEEMO.
Old Nov 12, 2009 | 08:36 AM
Free bump, sorry I don't know where it is on your car.
Old Nov 14, 2009 | 01:08 PM
priestyboy369's Avatar
priestyboy369
It should be in the same place as the mk3 fiesta just behind the fire wall on the passenger side. so no need to take the dash apart. pretty sure thats right.
Old Nov 18, 2009 | 03:30 AM
fordwithapassion
Thanks priestyboy, im going to have another look at it today and hopefully get it sorted. Many thanks to all of you for your help.
big_Rad
Sep 15, 2017 09:36 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Topjoe9
Aug 20, 2015 02:38 PM
muz
Aug 16, 2015 12:57 PM
Roosie
Aug 15, 2015 08:09 PM
