Timing a v6 with decomp plates
Old Jul 13, 2009 | 07:27 PM
Shonky's Avatar
Shonky
V6 Ka of Love
Default Timing a v6 with decomp plates
I've put decomp plates in my v6, but all the timing marks are now all to cock because the heads are now spaced out 1.5mm each, how do I go about timing it without verniers?!?
When the belt is lined up with the crank and routed to the left head it's out by 4 teeth, didn't even bother trying to line up the right set of cams!
Help
Old Jul 13, 2009 | 07:44 PM
Shonky's Avatar
Shonky
V6 Ka of Love
If I line the crank up, route the belt up the left side with the roller loose its 4 teeth out, if I lined the crank up then lined the left cam up with the line on cambelt I don't think there'll be enough adjustment in the rollers to take up the amount of slack there'll be
Old Jul 13, 2009 | 08:10 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
You havent timed it properly, do it again, it cant possibly make it more than a tooth out, as you just pick the next tooth if it has!
3i Jim
Nov 20, 2015 05:12 AM
turbochild
Aug 27, 2015 08:40 PM
borboyous
Aug 22, 2015 11:17 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
