fire it up
Old May 24, 2009 | 08:02 PM
XRSTI's Avatar
XRSTI
Default fire it up
hey people when settin the ignition timing on me xr3i do i do it with vacum on or off at the dizzy
Old May 24, 2009 | 08:08 PM
haz87's Avatar
haz87
Off and block the hose with something
Old May 24, 2009 | 08:11 PM
XRSTI's Avatar
XRSTI
cheers do i set it at 12degrees btdc yeah
also with the vac on after settin it looks to be at about 22 -24 degs btdc is that right
Old May 25, 2009 | 10:03 AM
haz87's Avatar
haz87
12btdc is running super unleaded. If its advancing that much when you plug it back in again, it sounds like its plugged into a direct manifold vacuum port. It should be on a ported vacuum port (before the throttle blade)
DixieTheKid
11
Jun 6, 2020 11:20 AM
Jun 26, 2017 06:18 PM
Bailes1992
Sep 19, 2015 02:17 PM
DixieTheKid
Sep 14, 2015 09:04 PM
