t34 play in shaft
Old May 24, 2009 | 06:20 PM
rs tingle's Avatar
rs tingle
Default t34 play in shaft
iv just brought a engine with a turbo on which is not really needed but it has play in the shaft side to side quite a bit of movement and i cant really tell weather it has in and out movement i dont now what spec the turbo is i think its a t34 the exgauhst housing is 48 and the peler housin is 60 if any help i waswondering how much would a rebuild be for one
Old May 24, 2009 | 06:24 PM
GUZZLER's Avatar
GUZZLER
prime it with oil then recheck the play, normally about half a mm side to side but no in & out.
Old May 24, 2009 | 06:27 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
is it? my turbos still good then with very slight side to side
Old May 24, 2009 | 07:20 PM
Putting oil in it is a bit pointless as it is the pressure that stops some play, so long as you can't see the wiggle side to side, and can only just feel it still got life left in it, it floats the shaft on the oil film between it and the bushes surrounding the shaft so of course there must be room for the oil to get into, hence the play.
Old May 25, 2009 | 12:36 PM
cossieDavedree's Avatar
cossieDavedree
360 thrust bearings have slightly more play though anyway
Cosnada
Jan 7, 2016 05:30 PM
Russ Payne
Sep 25, 2015 08:29 PM
