Taking ages to boost up ?
Old May 16, 2009 | 06:39 PM
sparkys2turbo's Avatar
sparkys2turbo
Default Taking ages to boost up ?
My erst takes ages to start pulling, just over 4000 rpm any ideas.
Old May 16, 2009 | 06:53 PM
ste45's Avatar
ste45
what boost you running , if its high its guna take longer to build up making it laggy . 4000rpm does seem a bit late tho , is it set up ryt ? might be worth getting it checked over by a pro .
Old May 16, 2009 | 07:14 PM
sparkys2turbo
..17psi. I took her for m.o.t emissions were so they messed about wihig4h th got problems with timing to its running really retarded if you advance it, it pinks. Also the screw what adjusts the throttle linkage position, is pusing the throttle open where before it wasn't even touching it.
Old May 16, 2009 | 07:18 PM
ste45's Avatar
ste45
mines runs 17psi also and my turbo starts spooling up bout 2000 and on full boost inbetween 3 and 3500 rpm i think , supose it depends on the setup you have tho
Old May 16, 2009 | 09:59 PM
sparkys2turbo
Originally Posted by ste45
mines runs 17psi also and my turbo starts spooling up bout 2500 and on full boost inbetween 3 and 3500 rpm i think , supose it depends on the setup you have tho
Mine starts pulling at 4000 rpm 4500 rpm its on full boost but then hits rev limiter which is 5800 so it dont feel your getting much pull in each gear, starting 2 think it might be turbo but dont smoke at al
Old May 17, 2009 | 07:57 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
mines the same ,dont really go anyway till 4200 rpm,then it runs out of revs,but i think its a stage 3 hybrid.so will be a bit laggier,but to be honest its crap lol
JK12
33
Apr 26, 2021 12:09 PM
STAFFY OWNER
18
Sep 21, 2015 02:50 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
