Escort Rs turbo Overheating
Old May 16, 2009 | 01:48 PM
daviddunlop83's Avatar
daviddunlop83
Default Escort Rs turbo Overheating
The car still seems to be overheating after having it set up and running fine on the rolling road at 190bhp but even driving it normally down the motorway the temperature is going right up near the red until you turn the heaters on full
The car has a new re-cored rad, with pro alloy front mount intercooler.
Couple of things i want to check
What does that valve do in the picture for the coolant system? The one with the white plug
Also does it matter which way round the hoses go onto the heater matrix? The bottom one going to the Y piece
If these are correct what could be causing it to run so hot?
Old May 16, 2009 | 01:53 PM
studabear's Avatar
studabear
has it ever had a new water pump, is the coolant correct mix of anti freeze, is the thermostat operating correctly
Old May 16, 2009 | 01:55 PM
daviddunlop83
It hasnt had a new water pump but the engine is just rebuilt and had a new thermostat when rebuilt and was overheating and has since been changed again since to a genuine ford one.
IF you take the small hose off the top of the thermostat housing the water is coming out of there but its now flowing out quickly. How much should come out of there or what is the best way to test the water pump to see if its working properly?
Thanks
Old May 16, 2009 | 01:59 PM
jsXR3I's Avatar
jsXR3I
Im having the same prob mate but mine has had a new water pump and its still doing it :-(
Old May 16, 2009 | 02:01 PM
studabear's Avatar
studabear
not really sure how to test water pump, but for what they cost and the ammount of time they take to fit, I would consider replacing even just to eliminate it from possible causes of your problem
daviddunlop83
Its a pain in the arse. Let me know if you figure out what it is. I will let you know if i can. Did you change your thermostat?
Do you have a pro alloy front mount intercooler?
Old May 16, 2009 | 02:02 PM
studabear's Avatar
studabear
another thought
is the temp sender accurate? is the fan coming in when its supposed to?
Old May 16, 2009 | 02:06 PM
daviddunlop83
another thought
It had a new fan switch and temp sensor but it melted the fan switch or something shorted out and the plug was damaged too so we just got the new fan switch yesterday and the plug. We did however put the fan on a switch.
But with motorway driving at 70 it shouldnt need teh fans on anyway?
I quite sure the temp sensor is correct but i have ordered a new one from ford also.
Old May 16, 2009 | 05:33 PM
twolitrepinto's Avatar
twolitrepinto
at 190bhp maybe you just need a bigger rad??
is it a 1.6 CVH or is it ZVH? - i hear ZVH's can have head gasket issues
if youve recently emptied the water system you could have an airlock...
could be a number of things.
just a thought aswell, not sure how the pipes go but make sure that both the water pipes going to the heater matrix are coming from a T piece...
basically what i mean is, if you turn the heaters to cold, its not going to stop it circulating to somewhere else!
Old May 25, 2009 | 02:33 PM
daviddunlop83
Bit of an update,
We removed the thermostat completly to see if that helped and it hasnt
The fans are coming on when they should but its running too hot and they dont turn off again once that have came on.
Any other ideas to what could be the problem?
Old Jun 5, 2009 | 11:43 PM
twolitrepinto
are the hoses all getting hot? does the rad get hot?
could be blockage in rad.
could be water pump not pushing the water round.
its not uncommon for a cvh water pump to go.
Old Jun 5, 2009 | 11:44 PM
twolitrepinto
easiest way would be to remove the water pump, turn the pulley and see if the wheel turns the inner part. might aswell replace it for what they cost
Old Jun 6, 2009 | 07:25 PM
Maki's Avatar
Maki
I had the same problem with my CVH when I had it... I did so many things and nothing helped. My conclusion was that my intercooler is blocking the air that should go to rad.
I had a sugestion to seal everything around the rad, so that air would be traped and had no other way to go just through the rad.... never done it as I changed to ZVH later, but you could give it a go.
Old Jun 12, 2009 | 12:39 AM
twolitrepinto
if the electric fan is working it wont matter about the intercooler in front of it, the air will get dragged there anyway by the fan. must be something to do with rad tho because turning the heaters on is cooling the engine. in effect the heater matrix is doing the radiators job.
make sure there is water getting to the rad, check all the rad pipes are getting hot and feel the rad itself. make sure the fan is cutting in when it should.
is there a small return pipe coming from the top of the rad to the water bottle? if there is check this is not blocked because its a self bleed mechanism to stop the rad airlocking.
Old Jun 12, 2009 | 08:34 AM
Maki's Avatar
Maki
No it comes from thermostat housing on CVH
Old Jun 12, 2009 | 04:59 PM
Mark RS's Avatar
Mark RS
it was blocked mate, we have a std cooler on it for now, but were are going to put the pro alloy one back on and fingers crossed
Old Sep 16, 2009 | 07:55 AM
chunk of stoke's Avatar
chunk of stoke
i have a 1993 mondeo 2.0lt zetec with a turbo conversion on it the block is standard but the car keeps getting hot and overheating any clues its had new headgasket on and new water pump its in a fiesta n reg si its got a rs2000 rad on as well any1 help
Old Sep 16, 2009 | 08:09 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
couple of things to try, fitting an oil cooler, not the ford oil warmer, but a proper mocal type one.
also disconnect water cooling to the turbo, just let the engine run on a bit after a hard run, you'll see a big drop in water temps and won't really affect the turbo's life span.
i run a 1.8 zvh, was running 190bhp or thereabouts i didn't have any overheating problems at all, this is on my mk2 fiesta, with standard rad.
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
FlashRS
Sep 14, 2015 12:36 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
