zetec turbo tapping noise
Old Apr 19, 2009 | 07:55 PM
GrantCraik's Avatar
GrantCraik
Default zetec turbo tapping noise
ive got a silver top zetec turbo in my focus, hit the limiter today and it started to missfire then cut out i started it up again and it sounded like it was fireing ok but there is now a tapping noise coming from the engine, anyone know what this could be? thanks
Old Apr 19, 2009 | 09:20 PM
GrantCraik's Avatar
GrantCraik
anyone?
Old Apr 19, 2009 | 09:22 PM
RS 5tu's Avatar
RS 5tu
take the cam cover off and see if there is any thing obvious.
Old Apr 19, 2009 | 09:30 PM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
have you got plenty of oil in the engine as it could be the tappets or maybe a bent valve , but my fiesta rs 1800 bounces off the 7000 rev limiter every day
Old Apr 19, 2009 | 10:01 PM
GrantCraik's Avatar
GrantCraik
ill have a look under the cam cover and top up the oil if it needs it tomorrow, how can i check the tapits? and is there a way of checking the valves without taking the head off? cheers
Old Apr 20, 2009 | 08:28 AM
GrantCraik's Avatar
GrantCraik
Old Apr 20, 2009 | 10:13 AM
You can check for a bent valve by doing a compression test, the zetec should be quite happy at the limiter all day long.
Most likely just a dodgy lazy hydraulic tappet.
Old Apr 20, 2009 | 10:30 AM
OldDan's Avatar
OldDan
Is it wise to ask what the limiter is set at first?
Old Apr 20, 2009 | 12:51 PM
GrantCraik's Avatar
GrantCraik
not too sure the rev counter goes to zero after 6000 think it might be somewhere near 7000 the dyno graphs i got go upto about 7 but suppose that doesnt say much.
Old Apr 20, 2009 | 05:32 PM
My auto mondy used to hit 64/600rpm before limiter.
robnock
21
May 13, 2019 05:29 PM
Chopshop85
Aug 17, 2015 06:38 PM
Churtz
15
Aug 13, 2015 06:40 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
