zetec turbo compression
Old Mar 30, 2009 | 05:35 PM
Dan1281's Avatar
Dan1281
Default zetec turbo compression
as i dont have the cash to go buying special pistons, to lower the compression on a zetec am i better off fitting a de-compression plate or skimming the pistons a bit?
thanks for any help
Dan
Old Mar 30, 2009 | 05:58 PM
JonathanJ's Avatar
JonathanJ
To be honest I dont like either method , decompresion plate means 2 head gaskets and therefore more possible failure areas , and machining pistons removes material from a point where turbo engines suffer anyways ...... if I had a choice it would be decompression plate as the possible failure should not be a catastrophic one , where a piston failure could take the whole engine and debris into turbo aswell , just my thoughts
Old Mar 30, 2009 | 08:06 PM
Dan1281's Avatar
Dan1281
thats a good point, if the head gasket blows its not the end of the world i suppose, although ferriday reckon you can use one of thairs with only one gasket and some type of sealing compound
out of interest do you know the std compression of a 2.0 zetec?
Old Mar 30, 2009 | 08:10 PM
Rick's Avatar
Rick
you can stack the MLS std head gaskets - 2 ST170/cougar gaskets will give you 2mm thickness. Mike @ Ferriday is a very clever bloke, i'd listen to him.
Rick.
Old Mar 30, 2009 | 08:13 PM
Dan1281's Avatar
Dan1281
Rick.
sorted then, i'll order one of them when i build the zetec, i'm going to turbo my std 3i first then build a zetec when it blows up, may aswell, i'd only bin the engine anyway
cheers mate
Old Mar 30, 2009 | 08:15 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
i bort a 2mm decompression plate from ferriday,use 1 headgasket and compound sealer,but headgasket didnt last long at all.
Old Mar 30, 2009 | 08:16 PM
mad dog younge's Avatar
mad dog younge
i built a buget one .and put a de comp plate on it .compression ratio was 9;1 as i fitted a 1mm de comp plate .only used 1 head gasket .it made 225bhp at 8psi on the rollers .and still running stong
Old Mar 30, 2009 | 08:20 PM
Rick's Avatar
Rick
gasket failures on Zetecs are almost always down to the finish not being correct on the mating surfaces, they need to be substantially smoother than composite type gaskets, and a lot of machine shops can't replicate the oe finish.
Rick.
Old Mar 30, 2009 | 08:22 PM
Dan1281's Avatar
Dan1281
thats brill, what spec is the engine? i'm after around that power.
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
