Zetec Turbo How Much Boost?
Old Mar 25, 2009 | 12:26 PM
siward's Avatar
siward
Default Zetec Turbo How Much Boost?
What boost can i run on a 2.0 zetec turbo engine running on ofab management, rover turbo inlet manifold, beige injectors, area 6 uprated valve springs, focus rs pistons and rods and focus rs metal head gasket?
I have it booked in on monday to have my evolution chip fitted and setup. Chip has been wrote to engine spec.
I was thinking 16 or 21 psi?
Any help would be apriciated.
Si
Old Mar 25, 2009 | 01:00 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
sounds a good spec mate.how much did it cost u for all that mate?
ask the chap whos mapping it about the boost and leave it at wotever he sets it at.
Old Mar 25, 2009 | 01:02 PM
GribbiN's Avatar
GribbiN
My Focus RS was peaking at 26PSI
21psi is a good safe number
Old Mar 25, 2009 | 01:11 PM
siward's Avatar
siward
Cheers mate, Cost around 4k
Old Mar 25, 2009 | 01:12 PM
siward's Avatar
siward
Talking
Sorted, 21psi it is then
Old Mar 25, 2009 | 06:08 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
So many experts
The amount of boost you can run will be limited by detonation or fuel.. and on beiges, assuming you mean 701's, on a 2 litre (even on a small T3) i doubt you'll be runing much more than about 10 pounds of boost before you max the injectors out!
Your tuner should be the person you ask this question to... or more to the point, he'll tell you what its running and thats that!
Old Mar 25, 2009 | 06:09 PM
RS 5tu's Avatar
RS 5tu
Not much on 701s
Old Mar 25, 2009 | 06:14 PM
RS 5tu's Avatar
RS 5tu
i would say you need at lest 350cc injectors to get half decent power but the bigger the better.
I am building a ZT my self FRS Rods and pistons FRS Cams Blacktop engine 680cc injectors and rover turbo inlet. Just need to get some valve spring asap
Old Mar 25, 2009 | 07:44 PM
siward's Avatar
siward
ok, so what injectors do i need and where do i get them from?
Si
Old Mar 25, 2009 | 07:49 PM
bad boy rs's Avatar
bad boy rs
if you change injectors youll need a new chip
Old Mar 25, 2009 | 07:54 PM
woolford's Avatar
woolford
i have one i built.. frs pistons and rods arp bolts through out. double valve springs thinking of a ported head.. want between 280-320..
Paul
Old Mar 25, 2009 | 07:55 PM
siward's Avatar
siward
I thought beige injectors were good for 16psi? a mate had a 1.8 zvh turbo and was running 16psi on blue injectors, he had beige before the blues and it was over fueling so he changed back to blues
Si
Old Mar 25, 2009 | 08:11 PM
RS 5tu's Avatar
RS 5tu
Paul
Where did you get your springs from area 6?
Old Mar 26, 2009 | 07:24 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Si
That isn't how it works. Speak to your tuner.
Old Mar 26, 2009 | 09:46 PM
woolford's Avatar
woolford
no mate had FMS do the work cleaned it etc
Old Mar 30, 2009 | 10:58 AM
siward's Avatar
siward
Just got back from Hitech Motorsport.
Van is 271bhp at 6050 rpm running 10psi boost. Fueling is good and is enough for 16 psi but was getting boost cut. Going to replace map sensor, plugs and take it back
Si
robnock
21
May 13, 2019 05:29 PM
gchristophi
Aug 31, 2015 10:36 PM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
