2.0 PINTO
Old Mar 10, 2009 | 09:24 PM
combi van man's Avatar
combi van man
Default 2.0 PINTO
would the pinto engine out of a transit fit straight in my sierra?i know the gearbox does'nt but ive already got that.any addvise would be great.
cheers
Old Mar 10, 2009 | 09:58 PM
cabriolet's Avatar
cabriolet
yes but engine is low power version iirc not sure what umean about gearbox the transit used the same box different ratios i think
Old Mar 10, 2009 | 10:22 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
As said it will bolt straight in but the transit lumps were lower power
Steve
Old Mar 11, 2009 | 12:16 AM
Dan1281's Avatar
Dan1281
the transit pintos are lower compression, ripe for a turbo conversion, i had one in my old capri, a 202 block it was
Old Mar 11, 2009 | 12:40 PM
B16CVH's Avatar
B16CVH
Correct
Old Mar 11, 2009 | 03:26 PM
combi van man
been told its a 205 block so maybe its been changed.
Old Mar 11, 2009 | 03:29 PM
combi van man
if its a 202 then i would like to turbo it.where would i get exhaust a manifold from?
Old Mar 11, 2009 | 03:54 PM
The Youth.'s Avatar
The Youth.
they are very rare but turbo technics used to make one, you could make one yourself as many have in the past.
steve
Old Mar 11, 2009 | 07:53 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Be careful - The Cossie 205s were carefully selected for wall thickness - make sure the cylinders are coded 2 or 3. The code is punched onto the block under the distributor. Thin walls are ripe for a block explosion
Old Mar 11, 2009 | 08:02 PM
Dan1281's Avatar
Dan1281
pinto turbo i mocked up about a year ago, never finished it because our garage went under
would've been good
mk3ste
Oct 17, 2021 10:09 AM
chowfornow
14
Jan 5, 2019 09:01 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
20/20 vision
Sep 29, 2015 11:27 AM
The Enigma
Sep 29, 2015 10:31 AM
