Temp gauge not working or just sits at top!
Old Nov 29, 2004 | 05:18 PM
stusfesta's Avatar
stusfesta
Default Temp gauge not working or just sits at top!
hi wondering if anyone could help me! i have an escort van 1.8zetec and the temp gauge is playing up, the needle will just go above the red when i turn it on sometimes and then slowly sits back down and far as it can go! any ideas?
thanks
Old Nov 29, 2004 | 05:23 PM
davidnormanuk's Avatar
davidnormanuk
Sounds like a loose connection to the temp sender on the engine. If you earth out the wire that goes to it you should see the temp gauge go right up to the top. If it does this when on the sender unit, it could be time to replace it.
Dave
Old Nov 29, 2004 | 05:37 PM
K18NEO's Avatar
K18NEO
Fetch it out of the block, clean it and put it back in. Sorted!
Old Nov 29, 2004 | 05:38 PM
stusfesta's Avatar
stusfesta
ok mate i will try that, thanks a lot
Old Dec 6, 2004 | 05:19 PM
stusfesta's Avatar
stusfesta
i took the unit out and cleaned it and it still isnt workin, i also earthed the wire and the temp gauge shot up, new unit?
Old Dec 6, 2004 | 09:33 PM
Alvyn's Avatar
Alvyn
then It must be the sender unit that's in the head that's @ fault cost u about tenner for a new one
Old Dec 7, 2004 | 11:00 AM
tont2002's Avatar
tont2002
It hasnt got any aftermarket gauges on has it......
If so, the temp needle may have been put back on the wrong position, so when the ignition is turned on, it auto sits at zero, and if the needle is in the wrong position that maybe in the red...... make any sense???
Steve
Old Dec 7, 2004 | 04:54 PM
stusfesta's Avatar
stusfesta
Steve
well it has had the gauges changed with the engine but it was all working fine when i bought the car so a recon the sender in knackerd, the gauge doesnt move at all now it just sits at the bottom ile just get a new one!
Old Dec 13, 2004 | 06:08 PM
stusfesta's Avatar
stusfesta
got a new sender and it works fine now. yay!
Old Dec 13, 2004 | 06:45 PM
Alvyn's Avatar
Alvyn
who HAVE to learn to listen m8
Old Dec 13, 2004 | 07:28 PM
stusfesta's Avatar
stusfesta
lol cheers mate
manuel boeckx
13
Oct 3, 2015 02:29 PM
COSWORLD
Aug 14, 2015 07:40 AM
no1trancefan
Ford Focus ST
Aug 7, 2015 09:21 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
