help no power 2 fuel pump
Old Feb 22, 2004 | 05:43 PM
s1 2oobhp's Avatar
s1 2oobhp
Default help no power 2 fuel pump
efi cvh 1600cc
what colour is the relay as its not the same as the mfi relay colour
Old Feb 22, 2004 | 08:49 PM
Rick's Avatar
Rick
not pink then?
Old Feb 23, 2004 | 10:12 AM
HI.
If its series1 rs turbo its silver under drivers side footwell, s2 is pink same position
at footwell, try fuse in the fuse box first ,if the fuse is ok bypass fuel relay at base of relay by bridging pin30 and 87 at relay base with a piece of wire pump should run if pump does not run check at pump for battery volts,
Dave,
Old Feb 23, 2004 | 10:39 AM
s1 2oobhp's Avatar
s1 2oobhp
now thats what i need cheers dave only 1 prob is its a efi cvh xr3i
Old Feb 23, 2004 | 10:41 AM
s1 2oobhp's Avatar
s1 2oobhp
mean it is a efi cvh xr3i
Old Feb 23, 2004 | 11:22 AM
check the fuel cut off switch in the spare wheel well
Old Feb 23, 2004 | 12:37 PM
hi,
i assumed by your title s1 200bhp. u were running a escort turbo, with efi pump,
but now not sure, is it 1.6 efi xr3i, if so same checks to find out if pump or relay,
or fuse,
Dave,
Old Feb 23, 2004 | 09:15 PM
s1 2oobhp's Avatar
s1 2oobhp
just a mates cars we fitted a new fuel pump fse type now got no power 2 it
thing is dont no what colour the fuel pump relay is as its not the same as the mfi
Old Feb 23, 2004 | 09:18 PM
s1 2oobhp's Avatar
s1 2oobhp
checked the fuel cut off valve thats ok
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
slammedorion
15
Nov 1, 2015 07:17 PM
hopper350
Sep 4, 2015 12:53 AM
jonjg
Sep 1, 2015 03:46 PM
