stg3 cossie not holding boost?
4x4 saff running greens etc,boost max's at 25psi but then drops to 19/20
psi,have just fitted a forge racing actuator with a range of 20 to 28psi but still not holding boost pressure or is this normal to lose 5/6psi,please help
i think it will fit as i was looking for one for mine but i went for a 34 in the end as a t4 on my car would have been the end of me!
all depends on how far you want to go really mate?
a t34 with the .48 housing would see you to around 370ish bhp max or a t34 with the .63 housing is good for around 400bhp.
and a t4 will make it pretty horrid around town cause there laggy as fook!
whatever you fit you would be better getting a 2wd manifold on there as well cause they flow much better!
dont know if you need to move anything to fit the 2wd one but im guesing not as lots of the big bhp boys do this.
Thanx for the advice mate,had heard before that the 2wd manifold
is better for flow but i used to have a 2wd saff and i had to have
manifold studs drilled out after they had snapped,will stick to my
manifold and go for a t34 as im only after 350/370bhp.
would there be a noticeable difference between 48/63 housing on
a t34? majority of my driving is round town so the less lag the better,
what housing did you go for?
Love the look of your car mate bet she's a bit of an animal
I have just had mine set up, i am using Greens, 3Bar and -34 , We had to remove the amal valve as i was having the same problems with wavering boost and fitted a Bleed Valve set to 21 Psi Held. Came out at 310 BHP !! A runs really well.
Al......
Al......
Originally Posted by PJay
t34 will not make 400bhp for long untill it dies, 370/380 MAX
i have seen this question asked lots of times on here and the general consensus was that a .48 could make 370ish but it gets bloody hot after 350bhp so not really a good idea, and that a t34.63 was happy at 380bhp but could be run up to 400 with no problems.
am i wrong again? lol
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
