deisel gearbox help
Old Feb 20, 2009 | 06:12 PM
zimonfieldy's Avatar
zimonfieldy
Default deisel gearbox help
ive got a series 1 rs turbo and i want to put a deisel box in.ive got a new rs clutch 220m with series 2 flyweel and a 1.8 diesel thrust bearing,but with the box on dosent seem to have much leveridge on the arm but still engages the clutch ok.is this normal?i dont know beacause the engine is out the car at the minute.it also seems like the cable will be slack but as i say i dont know yet can anybody help?
Old Feb 20, 2009 | 06:27 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
when fitted ajust the clutch ratchet and all should be fine. but why are you fitting a diesal box? and befor you say its stronger its a big mith im afrayed all the bairings are the same in the bc boxes
Old Feb 20, 2009 | 06:43 PM
Ade's Avatar
Ade
Fast Ford snapper
All you'll get is one-wheel-drive
Prob as good a time as any to abort and go find an LSD box!
Old Feb 20, 2009 | 07:40 PM
s1cab's Avatar
s1cab
i had this with mine ! i fitted an escort mk5 pedal and quadrant this way you can adjust it yourself. worked great for me ! straight forward 2 !
Old Feb 20, 2009 | 07:49 PM
zimonfieldy
had a brand new deisel gearbox given to me.do i need a series one metering unit to match a series one loom as i dont have one?
Old Feb 20, 2009 | 10:01 PM
bortaf's Avatar
bortaf
Did the same on a S2 i used the turbo release bearing, the turbo and diesel clutch kits are a differant part number but they use the same release bearing according to the QH catalog ?
But they do use differant ratchets i beleive to take into account the differant lifts on the clutch covers ?
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
