ERST S2 Backfiring and possible Overboost? NEED HELP ASAP :D
Old Feb 2, 2009 | 01:02 PM
Shep_Cobain's Avatar
Shep_Cobain
Default ERST S2 Backfiring and possible Overboost? NEED HELP ASAP :D
Basically i think i know what the problem is guys but just need to check before i send it in.
Basically a while back my actuator rod clip snapped so the actuator wasnt working hence no boost.
It didn't matter because it was going into MSD in Bispham the following day for the setup.
They sorted it out and it felt great. I didn't really drive the car for a while and when i did never really ragged it or used full boost.
But when ive started driving it more (since its cold outside ), when it warms up and i boost to 14psi it cuts off and hits 0 revs and backfires sometimes.
If i stick to 10psi on my gauge in the car its fine.... However, i can hear and feel the turbo starting to boost at -4 psi
So.... no probs at 10psi..... as soon as i goes above it cuts off and doesn't boost.
Is the problem is that the car is overboosting and maybe when the actuator rod clip snapped and the rod came unattached from the wastegate, it maybe twisted causing psi to increase????
MSD wouldnt of known about this when the car was set up. They just set it up for a 14psi boost. Sometimes it will boost to 14psi and its fine for about 5 seconds and if i take my foot off the gas it will be fine. But if i boost for 10 seconds at 14(max) it will start to back fire and hit 0 revs and cut off.
Oh, when it went in for the setup MSD advised to get a new or reconned turbo soon.
Im no offay with cars so i hope i havent confused with my lack of knowledge and wordings.
Help would be appreciated
Thanks fellas.
Old Feb 2, 2009 | 02:35 PM
Rs1's Avatar
Rs1
Yep just sounds like hitting factory boost limit, must be on a standard chipset/ecu??
Old Feb 2, 2009 | 02:37 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
yeah sounds it,maybe it aint chipped mate.
Old Feb 2, 2009 | 03:20 PM
Shep_Cobain
Really :O
Wouldnt MSD have picked this up as i told them it was chipped.
The guy i bought it from (RSOC forum) said it was. Genuine bloke aswell - new his stuff etc.
Old Feb 2, 2009 | 05:25 PM
B16CVH's Avatar
B16CVH
Sounds like a standard ecu to me??
Old Feb 3, 2009 | 08:49 AM
Stu @ M Developments's Avatar
PassionFords Creator
Hi,
PM me your registration and i wil take a look at your work report.
Old Feb 3, 2009 | 11:15 AM
me_again's Avatar
me_again
id say standard ECU as mine had the same problem
Old Feb 4, 2009 | 09:35 AM
Shep_Cobain
Originally Posted by Stu @ M Developments
Hi,
Done mate.
Old Feb 6, 2009 | 11:09 AM
Shep_Cobain
So how do i check if its been chipped or not?
Old Feb 7, 2009 | 10:27 AM
Shep_Cobain
Any luck Stu?
Old Feb 7, 2009 | 08:28 PM
s1cab's Avatar
s1cab
i doubt it is chipped. standard ecu's normally cut on 12psi. i'd try and get hold of another ecu that u knows chipped just to 100% confirm ! but 99% positive thats what it is !
Old Feb 7, 2009 | 09:09 PM
Shep_Cobain
Just waiting on Stu @ MSD but he hasnt got back to me yet
Old Feb 10, 2009 | 07:44 AM
Shep_Cobain
going in for service thursday, then possible brakes changing friday and fixing speedo.
Then ill pop to MSD as Stu hasnt got back to me
erm... how do i check if its chipped?
Mc5506
Oct 5, 2015 09:57 PM
beller
Sep 21, 2015 04:13 AM
Flatlinedan
Sep 18, 2015 12:41 PM
Flateric_2002
Sep 15, 2015 08:41 AM
Ellsa
Aug 9, 2015 07:03 PM
