water injection pump suppliers
Old Jan 13, 2009 | 06:25 PM
PAULDOLMAN's Avatar
PAULDOLMAN
Default water injection pump suppliers
hi guys
i've been looking around for a water injection pump for some time now, i can find companies who supply a whole kit but can't seem to find anyone who will supply the pump on it's own
can someone suggest anywhere i can try
Old Jan 13, 2009 | 11:29 PM
jon@work's Avatar
jon@work
according to the Escort Group A build manual, (see http://www.siipicossu.com/manuaaleja...-%20Engine.pdf )
2 of these were used :
Old Jan 14, 2009 | 04:05 PM
PAULDOLMAN's Avatar
PAULDOLMAN
cheers, what model can i rob them off?, coz most washer bottle pumps have 2 outlets don't they and i need one with one
Old Jan 14, 2009 | 04:49 PM
Go into any halfrauds, they have pumps on the shelf
Old Jan 14, 2009 | 05:29 PM
PAULDOLMAN's Avatar
PAULDOLMAN
what vechicle are the right ones
Old Jan 14, 2009 | 07:18 PM
It doesn't matter, ford did not do a special pump for the water injection, they grabbed the nearest one in the parts bin, it is purely a pump just get one with the conecctors on you want, but obviously a bottle fitting one would(?) be easier to mount as a reservoir for the water supply.
I think I would go off to the scrappies and have a rummage around.
Old Jan 14, 2009 | 07:23 PM
andrewg's Avatar
andrewg
these pumps i,m sure were only for homoligation, you probably want over a bar of water pressure over boost, so running 2 bar boost idealy you would want a 5 bar pump, you won't get that from them
Old Jan 14, 2009 | 07:24 PM
andrewg's Avatar
andrewg
i could get you one
Old Jan 14, 2009 | 07:53 PM
Mad Matt's Avatar
Mad Matt
Rally nut
How much, andrew ?
Old Jan 14, 2009 | 08:01 PM
PAULDOLMAN's Avatar
PAULDOLMAN
Originally Posted by andrewg
i could get you one
thanks pal, would be very gratefull, but from what i can understand i need a washer jet pumps which only has one jet hose connector at the bottom of the pump, i've got a puma water bottle im using but the connector at the bottom of the pump has two hose connectors which will be no good as the two must be linked together
Old Jan 14, 2009 | 08:26 PM
andrewg's Avatar
andrewg
don't get you?
Old Jan 14, 2009 | 08:39 PM
PAULDOLMAN's Avatar
PAULDOLMAN
well all i am saying is i don't know which car i will need to get them off as the one i have on my waher bottle has 2 jets and i guess i need one with one jet at the bottom of the pump
Old Jan 14, 2009 | 08:46 PM
marky_g's Avatar
marky_g
Fleet Manager
that pump gonna be powerful enough? u can but all aquamist parts spepratly
or try a caravan/motorhome/boats shurflow pump that's that devil kits us there about 80 quid
Old Jan 14, 2009 | 08:58 PM
PAULDOLMAN's Avatar
PAULDOLMAN
hi mark
i can't find anywhere thata sells a aqumist one seperatly, if u know of anywhere let me know as i'd prefere i of those
Old Jan 16, 2009 | 10:03 PM
markk's Avatar
markk
the early works cars used 2 headlamp washer pumps in series to get the pressure up, the WRC used a flojet pump albeit modified a little.
Old Jan 17, 2009 | 06:25 AM
A pump with two outlets is normally used for front and rear screen, one outlet going to front and one to rear, the current reverses causing the motor to spin backwards, and a little flow valve swaps sides inside the pump housing so directing flow as appropriate, this can be used no problem, as the valve will lock off whichever side is not being used when conencted to the lecky feed.
Old Jan 17, 2009 | 01:17 PM
marky_g's Avatar
marky_g
Fleet Manager
http://www.aquamist.co.uk/sl/plist/frm-4.html
they sell direct mate i had to ut parts for my set up
i no a place that sells flojet and shurflo too but there quite big
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
