Can i swap or not
Old Jan 12, 2009 | 06:52 PM
darrenr1969's Avatar
darrenr1969
Default Can i swap or not
i HAVE A VERY LOW MILAGE XR2 BOX, AND A S2 RS TURBO LSD BOX WITH A HOLE IN THE CASING....CAN I FIT THE LSD UNIT STRAIGHT INTO THE XR2 BOX...
I KNOW I HAVE TO STRIP THEM BOTH DOWN ,THATS OK I,AM HANDY WITH THE SPANNERS .
ITS TO GO BACK INTO MY XR2 SO THE RATIOS ARE FINE .JUST WANTED TO KNOW IF IT FITS,THANKS IN ADVANCE DARREN.
Old Jan 12, 2009 | 06:55 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
it fits im prity sure but you need a spicial puller to remove 5th gear spanners wont be up to the job also most of the time the 5th gear will crack as well
Old Jan 12, 2009 | 06:59 PM
kaking1982's Avatar
kaking1982
you need to change the crown wheel on the lsd as it wont match up with the ratios of the xr2 box . i did this to my xr2 box worked fine . i have to say have rebuilt loads of these gearboxes and not had one break a 5th gear yet
Old Jan 12, 2009 | 07:03 PM
darrenr1969
Thats ok i have already borrowed the fifth gear puller..and i actually have 3 boxes.....53,000 mile xr2 box....s2 lsd box with a hole in the casing and a escort diesel van box ,,,so i should be alright
Old Jan 12, 2009 | 07:05 PM
darrenr1969
THANKS FOR THE HELP KAKING THATS EXACTLY WHAT I WANTED TO HEAR
Old Jan 15, 2009 | 08:44 PM
darrenr1969
Right a little update.......the lsd diff went straight in and meshed perfectly..they weren,t interchangable because the lsd diff was an 8 bolt fitment...and the xr2 a 6 bolt fit...so that leaves the question what box is the lsd from the i.d tag states
87 WT UA
F0G 8B 04B
ANY HELP would be greatly appprieciated thanks in advance....darren.
Old Jan 16, 2009 | 06:31 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
8 bolt lsd is a S2 RST and a 6 bolt lsd is a S1 RST iirc
Old Jan 16, 2009 | 06:43 PM
Karlos G's Avatar
Karlos G
Balls Deep!
yup! i think you would need a S1 lsd in that case or a later xr2 box...
Old Jan 16, 2009 | 10:22 PM
darrenr1969
i don,t need a later box as i already have one,and the lsd fits fine . So it is a s2 box...thanks for that Bri ....
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
cossie brad
Sep 29, 2015 02:38 PM
grishenko45
Sep 9, 2015 12:58 PM
