turbo restrictors
Old Dec 18, 2008 | 06:14 PM
sapph rs's Avatar
sapph rs
Default turbo restrictors
i have the option of getting a group a turbo which unfortunatly has a restrictor fitted to the air intake.is it just a case of removing the restrictor and getting a larger intake hose or would i have to get another comp housing.
Old Dec 19, 2008 | 12:51 PM
Char1ie's Avatar
Char1ie
Both of my restrictors (36mm on the car and 38mm that came with the turbo) are machined into the housing. So you will almost certainly need a new housing. If you click the link in my sig I have a picture on my blog of my restictor and the housing it is machined into. I would post the image but it's blocked at work.
Charlie
Old Dec 19, 2008 | 01:32 PM
ian sibbert's Avatar
ian sibbert
The restictor (like the one below) unbolts from the intake on the compressor housing, then have new one machined out to your desired internal diameter (without the restrictor) but with the same external diameter and length and retaining the portion that slides inside the compressor housing, re-bolt it back in...job's a good un....no need to change the front housing
Old Dec 19, 2008 | 02:43 PM
Char1ie's Avatar
Char1ie
That looks different to the two I have as mine have no bolt holes to fix them on.
Charlie
Old Dec 19, 2008 | 03:14 PM
The last 34mm one I saw just sat inside the std cover sleeved down to 34mm then secured with 3 bolts around outer edge, through the std flange.
Old Dec 19, 2008 | 03:47 PM
ian sibbert
Charlie,
Yours is fixed here....
Old Dec 19, 2008 | 04:24 PM
sapph rs's Avatar
sapph rs
teah tabz is right mine has two bolts opposite each other screwing down onto the flange and a 3rd screw at the top that seems to do sod all.the thing is with this housing the flange does not go any slimmer at the top for the hose to connect to.and the restrictor is way too small for a t34 hose to connect to.from tis i think that the comp housing has been modded in some way.surely there must be a way round this as i dont want to restrict the car.any more advice people?
Old Dec 19, 2008 | 04:32 PM
ian sibbert
Can you not post a pic pal.....?
Old Dec 19, 2008 | 05:05 PM
sapph rs's Avatar
sapph rs
unfortunatly not usb nacked on comp i dont think i can describe it any better all of the retrictor fits inside of the compressor flange it is a genuine group a restrictor as it has 909 stamped on it if that is any help.the main concern is as i say the fixed flange does not go thinner at the top edge for fitting the hose if the restrictor is removed.it looks as if (even though it hasnt)that the flange has been cut down ie the thinner part fore the hose fitting has been cut off.
Old Dec 19, 2008 | 07:59 PM
sapph rs's Avatar
sapph rs
the turbo as my profile picture is fitted with basically the same restrictor as mine .as you can see the inlet flange is shorter than standard.so as far as i can see the only two ways around using the restrictor are either to get a larger inlet hose or change the compressor housing.am i correct in thinking this.as it looks like the inner of the flange has been machined to take the restrictor
Old Dec 19, 2008 | 10:03 PM
ian sibbert
This is what I mean...
This is as it is with the restrictor....
Either have the one you've got machined to suit the hose and remove the restriction...or make a whole new piece without any restriction and which suits your intake hose and that replaces your exisitng restrictor and mimics the original compressor housing dimensions....
Old Dec 19, 2008 | 11:26 PM
Red16's Avatar
Red16
My old t34 originally had a restrictor fitted, similar to the one [/b]ian sibbert[/b] posted above
So i made this to do away with the restrictor
it was then refined to do away with the unpleasant step/chamfer
Old Dec 20, 2008 | 01:50 PM
sapph rs's Avatar
sapph rs
the outlet you had made is what i think i could be looking for where would i be able to get one of the made and have you any idea of cost.
Old Dec 20, 2008 | 03:58 PM
ian sibbert
Making an outlet like that is really stright forward pal....any local engineering shop should be able to do you one...i'd guess about £50, if you get no joy send it to me and i'll knock you one up....
Old Dec 20, 2008 | 06:23 PM
I have a lathe but can't do those restrictors in piccie, not good enough yet!!
Have turned down some sockets for roosie to fit his head with long studs as std socket won't go in hole, quite proud of myself I was.
Old Dec 22, 2008 | 06:09 PM
Red16's Avatar
Red16
Not sure on cost tbh as i knocked it up at work from a bit of spare aluminium
Nice offer from Ian there
Nice to hear you're getting on well with your lathe tabetha, its just a case of thinking before you cut anything and not rushing into it, oh and practice. What lathe have you got? I'd love one in my garage at home.
Old Feb 3, 2009 | 10:51 PM
ian sibbert
I sent your restrictor today pete, you should have it tomorrow or the day after...
Some pics of it....
Old Feb 4, 2009 | 12:04 AM
RUBY123's Avatar
RUBY123
that looks the dogs would you consider making another
jessie_rs
62
Aug 6, 2019 09:27 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
