My Ford Probe sounds like a tractor! HELP!
Old Dec 16, 2008 | 07:40 PM
Hallowduck's Avatar
Hallowduck
Default My Ford Probe sounds like a tractor! HELP!
Hi Guys!
I am getting some strange noises coming from the engine bay of my Probe. It sounds like my car is a tractor! It is a ticking type noise like something inside is loose. It is there at idle and when you are cruising but it gets louder when you are decelerating using the engine. I have had something similar to this in a different ford and it turned out to be loose tappets and rattling push-rods. However I have heard that Probes have a tendency to make timing chain noises. Do you have any thoughts at to what it might be? How much it might cost to fix? Any help would be appreciated!
1995 Ford Probe
2L 4cyl Engine
116,000 Miles
Manual
Old Dec 17, 2008 | 06:52 AM
Can you post up a vid of it, as this would be a lot easier.
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
Lee Reynolds
85
Aug 10, 2015 05:56 PM
blakey100
Aug 4, 2015 08:17 PM
