Idle oil pressure for a Saph
Old Dec 12, 2008 | 07:42 AM
DAVE WRC's Avatar
DAVE WRC
Default Idle oil pressure for a Saph
Can anyone tell me the correct oil pressure on idle for a sierra saphire cosworth i recently did a oil change filled the car back up with oil upto the max marker on the dip stick guide when the car idles it running between 50 - 60lb on the gauge this to me seems alittle high i am worried i have put too much oil in
any help would be much appreciated
Dave
Old Dec 12, 2008 | 08:12 AM
fordsportjay's Avatar
fordsportjay
what does it drop to when warm.
im sure that engine has a high pressure oil pump in it
Old Dec 12, 2008 | 08:27 AM
LHD220Turbo's Avatar
LHD220Turbo
what oil did you put in it?
what tempreture was the oil?
was it started and left to idle? or was this after a run?
what pump do you have? high pressure or normal?
it all makes a difference
Old Dec 12, 2008 | 09:21 AM
DAVE WRC's Avatar
DAVE WRC
Havent left it running long because i was worried it was too high and would do damage
Temp therefore was cold wasnt even reading on the gauge
oil is 5w 40
got the car from jay he seems to think it has a high pressure pump on it but other than that no idea
Would it be safe to drive round the block to see if it drops ?
Old Dec 12, 2008 | 11:27 AM
callums's Avatar
callums
mine sits on about 60 from start up then drops to 40ish when warm
Old Dec 12, 2008 | 11:58 AM
LHD220Turbo
oil is 5w 40
firstly i'd change the oil for 10/50 (silkolene pro S is good)
the oil pressure needs to be taken when the oil is up to temp -
if its a high pressure pump then i dont think you have a lot to worry about - oil pressure is better than none at all
taken it for a run for 30 mins or so then see what it reads after that
Old Dec 12, 2008 | 01:31 PM
DAVE WRC's Avatar
DAVE WRC
Took it out for a run up the motorway and back
When idling its about 30 now and between 50 - 60 when running never goes over 60 tho
Old Dec 13, 2008 | 08:43 PM
Alvyn's Avatar
Alvyn
I'd say it has a high pressure oil pump so nothing to worry about!
ps I NEVER fill mine to the max mark on the dip stick
dombanks
Sep 21, 2015 08:38 PM
RSmark84
Sep 13, 2015 01:29 PM
Marino
Sep 12, 2015 11:10 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
