cozzy 4x4 tappet problem...DAM THING
Old Dec 9, 2008 | 08:42 PM
forevaford's Avatar
forevaford
Default cozzy 4x4 tappet problem...DAM THING
hi guys ive got a saph 4x4 coz an i have a problem with the tappets. they have always become noisy on idle after about a minuite. this engine was fully rebuilt about 2000 miles ago by myself. since the rebuild ive fitted new genuine ina tappets and found no difference worringly but naturley i suspected low oil pressure! so i plumbed in a op guage into the oil filter housing and found that even when the oil is at 100'c the pressure never falls below 1.8/1.9 bar (WHICH IS IN SPEC) yet they stil start to tap on idle!
im pullin my hair out now with this thing an i dowanto take the head bak off cus the gasket cost over 100£
anyhelp would be appreciated
thanks
mart
Old Dec 9, 2008 | 08:57 PM
forevaford's Avatar
forevaford
oh an i use mobile 1 15w50 oil
Old Dec 10, 2008 | 02:42 PM
IANS2RST's Avatar
IANS2RST
try relocating the oil take off for the turbo. on the 4x4 it comes out of the side of the head which means it takes some pressure away from the head. try blanking this & using the 2wd setup where the turbo takes its supply from the oil pressure swith take off. to do this you will need 2wd turbo oil feed pipe, adaptor union & either a different oil filter (escort 1.8 zetec filter fits nicely on mine ) or mess about moving the position of the ally oil takeoff the oil filter screws to to provide clearance for the oil feed union. also a suitable bolt to blank off the oil feed on the head
Old Dec 10, 2008 | 04:51 PM
forevaford's Avatar
forevaford
thanks, i have actually thaugt about doing that. but it still dousent explane what the problem actually is.
also another thing is on a morning when the engine is stone cold, when you start it it takes about 6 or 7 seconds for the oil pressure light to go off! and during this period all the tappet am rattling their bo***ks off, 6 seconds seems way too long for a oil pressure light to go off, it should go off after 1 or 2 secs shudnt it???
thanks for the info
Old Dec 10, 2008 | 05:00 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
try silkolene pro s engine oil..
Old Dec 10, 2008 | 05:33 PM
forevaford's Avatar
forevaford
iv tried a few oils now, it aint having any more. thats my next oil tho when its next worthy of change, u really recon it would make a difference with the silkolene??
tar
Old Dec 10, 2008 | 10:18 PM
fizzyturbo's Avatar
fizzyturbo
well dunno if this helps but i had noisy tappets, i got new ones dipped them in oil and fitted them and they were even louder, then i took them back out left them in a pot of hot oil for about 15 mins so the oil panitrates right into them and put them all back in and is now fine
Old Dec 11, 2008 | 06:17 PM
forevaford's Avatar
forevaford
i cant see it bein that because its ok when you drive it indercating that the oil has penetrated into the tappets ok.
im thinking oil pressure to the tappets is too low or even to the head!
if the block has 2bar oil pressure then shudnt the head have 2bar pressure??
im confused, my oil pressure in the block in just about in spec
Old Dec 12, 2008 | 12:37 PM
forevaford's Avatar
forevaford
i think iv worked it out
get rid of the cozzy an get the zetec turbo bak out
Old Dec 14, 2008 | 11:27 AM
forevaford's Avatar
forevaford
no 1 knos then???
Old Dec 14, 2008 | 11:54 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Like you say it seem like there isnt sufficient oil to the cylinder head therefore the tappetts arent getting what they need.
I cant see changing the turbo oil feed pipe position as being the cure tbh as there are loads of other 4x4 cossies out there using the standard oil feed take off and are perfectly fine, mine included.
If you have perfect oil pressure then i would suspect something amiss with the head possibly.
Old Dec 17, 2008 | 11:05 PM
forevaford's Avatar
forevaford
thanks mate, thas what i thaught, iv been out in it again tonite, give it a gud raggin an got it hot. the oil pressure is around 1.8/1.9bar @ idle.
is this low?
could i have some examples of other peoples please, when hot and at idle
thanks again
DixieTheKid
11
Jun 6, 2020 11:20 AM
tib2220
Sep 14, 2015 12:33 PM
truffleshuffle
Sep 10, 2015 09:35 PM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
