st170 dash lights flickering
Old Dec 9, 2008 | 10:04 AM
Darren_170's Avatar
Darren_170
oval never fails
Default st170 dash lights flickering
i done my battery to boot conversion and at high rpm my dash lights and only them start to flicker, the power within the car is fine its just the dash lights. i havnt got them turned rite up as i know they flicker on high. im not sure why they are flickering tho if everything is fine.
any ideas folks
cheers
Old Dec 10, 2008 | 08:51 PM
alexst0ne's Avatar
alexst0ne
Why did you do a "battery to boot" conversion?
Last edited by alexst0ne; Dec 10, 2008 at 08:54 PM. Reason: Didn't notice the other post...
Old Dec 12, 2008 | 01:55 PM
Darren_170's Avatar
Darren_170
oval never fails
eerrrmmm so i could free up space in the bay to fit a bmc and transferre the weight to the rear of the car, the car is tripped out n e way, only two seats mate, you do notice a difference, a didnt realise how heavy the battery was. everything is fine but its just my dash lights that flicker a little at high revs, i know there is a common fault with the dashlights anyway and you just turn them down a little but these flicker constantly at high revs, anyone got any ideas to how to solve this, i was mibi thinkin a power cap mite possibly help.
cheers folks
Old Dec 14, 2008 | 09:34 PM
Darren_170's Avatar
Darren_170
oval never fails
any one got ideas to why this flickering may occur, its really annoyin me an a dont know if thel cut out.
Old Dec 14, 2008 | 09:44 PM
RS Juto's Avatar
RS Juto
Mate the reason you dash board light flicker is due to the variable resistor in the light switch, If you replace the light switch it will solve it but it will soon start again. I have had 3 light switches in mine all under warranty, however im going to find a schematic and redesign the light circuit (thats what i do for a living) so it should be quite easy when i get the time
Hope this helps and i will post up a solution once i have one
Old Dec 14, 2008 | 09:50 PM
Darren_170's Avatar
Darren_170
oval never fails
thanks bud, i it quite easy to do,see it only started once i had done my battery boot convrsion and only happens in high revs although the car runs fine and no other lights flicker, does it sound familiar yeah or could i possibly need a booster or power cap, i used good cable aswell to compensate for the overall distance of the travelling voltage.
thanks mate.
155lee
Sep 6, 2016 11:10 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
imnoteasy
Sep 7, 2015 09:26 PM
fuzzy
Sep 4, 2015 10:11 PM
