engine problem
Old Dec 2, 2008 | 07:16 PM
neillo's Avatar
neillo
Default engine problem
hi all hope someone can shed some light on my engine prob
i have a t reg 1.8 tddi ford focus .the problem is:
first thing in morning or once its been stood at work all day it starts as soon as the glow light goes out but only runs on 3 pots lumpy and belts out white smoke but once normal operating temp is reached it kicks in on all four pots stops smoking and runs like a dream.ive had re con injectors put in and then it wouldnt bleed up so towed it to a garage who found 5 fault codes relating to fuel pump so 1200 pounds later and a new pump got car back and its just as before.its not using any oil or water to my knowledge please help thanks neil
Old Jan 18, 2009 | 09:41 PM
tiny2white's Avatar
tiny2white
Hi this sounds like the same problem i had on a mondeo there is a small solenoid on the throttle body (think its called a cold start solenoid) if it doesn't buzz when you turn the ignition on it's fooked. Mondeo was a v reg and had hundreds spent on it previous to me buying it, the solenoid cost Ł30 from fle bay! had exact symptoms as your focus.
Solenoid has small loom comming off it.
if you want a picture let me know
tony
Old Jan 19, 2009 | 05:23 PM
It's not the fuel cut off, as it starts, I would get your mixture checked as white smoke is not right.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
Blown Hell
Aug 5, 2015 07:22 AM
