Diesel Smoke
Old Nov 27, 2008 | 10:05 PM
alexno1dj's Avatar
alexno1dj
Default Diesel Smoke
Ive adjusted the fuel pump on my Endura lump. How much smoke would be acceptable for mot, its only noticeable in the dark in cars headlights that are behind me, in the day i cant see any in my wing mirrors apart from when i first start it. Do people think that would be acceptable?? cheers
Old Nov 28, 2008 | 12:28 PM
B16CVH's Avatar
B16CVH
Sounds ok to me!
Old Nov 28, 2008 | 02:10 PM
RichieST's Avatar
RichieST
Stand behind the car while someone revs the balls off it. If it looks too smoky, then the mot tester will think the same
Old Nov 28, 2008 | 03:28 PM
It's totally normal to see the smoke in cars headlights from a diesel, even when perfect, and even though you can't in daytime, I noticed this all the time in my diesel I had.
Old Nov 28, 2008 | 06:16 PM
alexno1dj's Avatar
alexno1dj
ahh right maybe im being abit fussy then, so i could actually turn it up some more, untill it starts to smoke when revved hard, then back it off abit???
Old Nov 29, 2008 | 09:31 AM
I only had a std 1.8 non turbo escort mk4 but turned mine up(lucas cav) quite a way, no smoke, but around 8mpg more, as it developed much more torque, had indicted 112mph, evetually but 0-60 was still measured in weeks!!
You always will see the diesel in car headlights it due to the unique properties of disel emissions and the light spectrum that headlight bulbs work on/at.
Old Nov 29, 2008 | 08:49 PM
alexno1dj's Avatar
alexno1dj
ok, see mine is alot better in 3rd and fourth and yes it seems to have more torque but still only gets to 90mph. mine is a lucas too.
Old Nov 30, 2008 | 09:56 AM
Mine used to get up to 80 quite quick, for what it was but took and age to accelerate after 100, make sure you use a genuine DELPHI filter, and shove some MILLERS diesel system cleaner in there, this is by far the best cleaner I ever used, use bio as well, as this defo perks it up.
I founf a lot of pattern fuel filters would not flow as well as the genuine dlephi ones, and held mine back a bit, a noticeable amount, and every little helps, also up the full pedal stop on pump, as they can take much more revs.
Old Dec 1, 2008 | 12:09 AM
alexno1dj's Avatar
alexno1dj
ok ill try all those things, does the throttle stop really make a difference. also what about airflow,would a cone filter with a cold air feed help.
also, do i need to reset my ecu.
cheers
Old Dec 1, 2008 | 07:39 AM
Induction side on this would probably offer no gains at all. some pump stops are set very low.
It would not hurt to pull the KAM fuse so it relearns, when you have done the above.
Failing this I would trot over to VAN AAKEN, to see if they can help.
Old Dec 1, 2008 | 04:36 PM
alexno1dj's Avatar
alexno1dj
so thats the small bolt that the throttle stops against when on full throttle?
Old Dec 1, 2008 | 05:45 PM
gup's Avatar
gup
where abouts is this screw as my 1.8d mk6 van needs a bit more poke
it quite nippy for it is but needs a bit more
Old Dec 1, 2008 | 07:27 PM
alexno1dj's Avatar
alexno1dj
its behind a cap at the front of the pump, u need an 8mm allen key.
Old Dec 1, 2008 | 10:56 PM
gup's Avatar
gup
cheers have you gotta take the timing belt covers and so on off to get to it fella cheers
Old Dec 4, 2008 | 12:03 AM
alexno1dj's Avatar
alexno1dj
no mate is just behind radiator, its a plastic cap u remove and its in there
Old Dec 4, 2008 | 10:25 PM
gup's Avatar
gup
cool cheers fella ill have a look tommorrow for it ,had a quick glace today but i couldnt see it
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Brickhouse
Sep 21, 2015 04:31 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
