1.8 Zetec - PROBLEMS!!!!!!! HELP!!!!!!
Old Nov 17, 2008 | 05:23 PM
Stoogey's Avatar
Stoogey
Default 1.8 Zetec - PROBLEMS!!!!!!! HELP!!!!!!
hey i have a 1.8Si escort (mk6) i recently put the cams, throttle body and MAF sensor from a 2.0L on it - sometimes i get quite a good bit of pull from it but other times, when putting your foot down in any gear it will keep going up in revs but lose all the torque (its not the clutch by the way) any help would much appreciated
Thanks
Old Nov 17, 2008 | 05:26 PM
djcossie's Avatar
djcossie
Thanks
u still got the 1.8 pcm in it , so its working 2.0 cams with 1.8 fueling
Old Nov 17, 2008 | 05:28 PM
Stoogey's Avatar
Stoogey
but it smells of petrol like no ones business! would it jus need a tune then? or a 2.0L ECU?
Old Nov 17, 2008 | 05:29 PM
djcossie's Avatar
djcossie
no reprogram your ecu or get a 2.0 one
Old Nov 17, 2008 | 05:32 PM
Stoogey's Avatar
Stoogey
i probably sound dumb but im not very good with mechanics - who can reprogram it? somewhere like power engineering?
Old Nov 17, 2008 | 05:33 PM
djcossie's Avatar
djcossie
no mate a ford dealer
Old Nov 17, 2008 | 05:35 PM
Stoogey's Avatar
Stoogey
serious!? didnt think they would touch anything like that... how much do you reckon it would cost?
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You're using the wrong MAF, that's why. You shouldn't just swap engine parts around - Ford had a pretty good idea about what they were doing when they built your 1.8
Old Nov 17, 2008 | 05:38 PM
djcossie's Avatar
djcossie
or just unplug the maf
Old Nov 17, 2008 | 05:40 PM
Stoogey's Avatar
Stoogey
ford had a good idea about economy not power. everybody i have spoke to on other websites has said use the 2.0L sensor - do you think the 1.8 one will work better?
Old Nov 17, 2008 | 05:41 PM
Stoogey's Avatar
Stoogey
any idea how much ford will charge?
i'll giv unplugging it a try and see how it gets on thanks for all your help peeps much appreciated
Old Nov 17, 2008 | 05:44 PM
djcossie's Avatar
djcossie
we charge 65+vat an hour
and it takes an hour
Old Nov 17, 2008 | 05:48 PM
Stoogey's Avatar
Stoogey
fair enough i'll try unplugging it and see if it works if not its off to ford thanks mate, by the way i have a set of rims for sale how do i post em up?
Old Nov 17, 2008 | 05:49 PM
djcossie's Avatar
djcossie
be a paid (gold)member lol
Old Nov 17, 2008 | 05:52 PM
Stoogey's Avatar
Stoogey
lol i think i'll be doin that very soon thought u mite have to do so many posts or sumink anyway thanks again
Old Nov 17, 2008 | 06:09 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
If you think your engine is running economically at full throttle (especially on a cat car), then you are sadly mistaken
The load calculation in the ECU is primarily generated by the signal from the MAF. By using the wrong MAF (eg, one with a different linearisation curve), you're just running in the wrong parts of the MAF. It's like running the wrong chip in a car. It doesn't work.
DOING IT WRONG
Old Nov 17, 2008 | 06:25 PM
MK4 CABI's Avatar
MK4 CABI
i have a 1.8 si, is this worth doing? how much extra power will this give.
Old Nov 18, 2008 | 04:40 PM
Stoogey's Avatar
Stoogey
if anyone can help - again - i have a 2.0L ECU, i plugged it in but the car wouldn't even turn over any suggestions? and to the above if it works i'll let ya know.
Old Nov 18, 2008 | 08:16 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Did you just completely ignore what was said above?
Old Nov 18, 2008 | 09:32 PM
Stoogey's Avatar
Stoogey
no actually it works now! 2.0L ECU cams throttle body and MAF sensor! i managed to get a guide that tells you what pins to change on the wiring loom plug swapped them around - started first time and goes alot better! thanks for all your help though
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
little bram
Sep 7, 2015 11:59 AM
