Urgent Help Needed!!
Old Sep 7, 2008 | 03:25 PM
wiser's Avatar
wiser
Default Urgent Help Needed!!
ive just charged my battery and put it back into the engine bay,i put the possitive cable on and being a comlete twat i then put the negative onto the positive terminal there was a small bit of smoke coming from the left hand side of the engine....wot have i done someone please help as the car will not start and there is no ignition light...its a 1990 xr2i 8v thanks
Old Sep 7, 2008 | 03:36 PM
You have most likely fried the alternator, at the very least, this is why you now have no ignition(alternator charge) light.
Old Sep 7, 2008 | 03:37 PM
wiser's Avatar
wiser
any way of testing 4 this??
Old Sep 7, 2008 | 08:56 PM
garyrsts2's Avatar
garyrsts2
mate i reckon u get an altenator, thats wer the electrics would go to and i reckon uv fried it.
Old Sep 7, 2008 | 08:57 PM
garyrsts2's Avatar
garyrsts2
you could take it out and have it tested somewhere or if u have another escort put it into it and see if it works, thats wat i would do anyway
Old Sep 8, 2008 | 06:30 AM
The quickest way of testing is to see if you have a EARTH at the IND terminal, this is the one onto which the blue wire to the warning light goes, when engine is stopped tis will be earth at this terminal, and will change to LIVE once running to show charging and so extinguish the bulb/light.
The part of the alternator that is affected is the regulator/rectifier, but not too expensive, around £45 should do a new recon ok.
Old Sep 8, 2008 | 03:33 PM
dunketh's Avatar
dunketh
Chief Iron Oxide Farmer.
Even if your alternator was fried you'd still be able to start the car.
Sounds like you've blown a fuse somewhere in addition to any alt damage.
Shouldnt have harmed anything else (ECU etc..) as the fuse box is the first inline to take a hit.
Old Sep 9, 2008 | 11:45 PM
andysfatrs's Avatar
andysfatrs
hi mate,
check the starter motor as the feed for this isnt fused from the battery and as has been already said check the fuses
Old Sep 10, 2008 | 05:15 PM
bloopeta's Avatar
bloopeta
a mate of mine used a set of jump leads once on an astra 1.7dti, he put them on back to front and had to have new ECU, new alternator and new starter. dont know if any fuses popped though
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
